Question about Canon ImageRUNNER 330s Copier
Does not print has blank copy
The copier feeds the paper but the copies come out blank. Put new toner in but still runs blank copies.
  • Canon Expert
  • 1,326 Answers
Before you added toner was it working OK, but it was asking for toner? If so the problem may be simple. The Blue lever you pushed down and to the right to release the Developing unit, was it locked in at the Nine o'clock potion? Is it now at the Nine o'clock position now or is it in a different position now. If so make sure it is at the Nine o'clock posisition now and that the front door can close correctly. Good Luck
Posted on Apr 20, 2008
HP4-smudged copies of printed text are appearing lower on the page...Any ideas on the fix
Run a 1/2 test.
Put paper in the manual feed tray(tray 1).
print something. And watch the paper. As the paper gets
about 1/2 way into the printer, open the top cover, remove the toner.
Look down at the paper. If you don't see smudged text, the fuser is probably bad.
If you see the smudging, replace the toner.
Dec 02, 2010 | HP : HP4 Laserjet Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Copier prints out blank paper
its is a bad, stuck laser shutter. It needs replaced with updated one. You could rip out the shutter but it is agaist the law to remove the safety feature.
Jun 20, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
Patchy Prints
I believe that the Heat roller in the Fuser has a build up of toner on it(in some areas) and as a result is not fully fusing the toner into the paper. when you use a thick setting you are actually slowing the speed down to allow more heat to the toner. the thicker paper causes more pressure allowing the toner to fuse properly. I would say you need a new Heat roller and possibley a pressure roller. You could try running 20 copies of a blank white page. Sometimes this will help. Poor fusing can also cause a previous image to come up on the next page or repeat itself down the page. A service call is in order if this does not work.
Hope this helps
Dave T
Mar 29, 2008 | Ricoh 6513 Copier
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
93 people viewed this question
old marine
old marine
