Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
The belt on cutting deck comes off of a pully.
    Brigadier General:
  • 3,917 Answers
Hi
Check whether the tension pulley under the deck is loose or not . Tighten the bolts on the pulley; your problem will be solved. If that won’t do then please follow the link bellow and go through the article to have an in-depth knowledge…
http://www.messicks.com/Articles/MowerDeckPerformance.aspx
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 12, 2010
Why does my mower deck belt on john deere 316 keeps breaking
There are a few causes for this and its not just this brand or model. First check that belt is installed correctly, check the part that keeps the belt on the belt rollers the belt should be between the garde and belt wheel, check for shine spots where belt is rubbing, Some times the mower deck is not set even or too low it can put the belt at too much of an angel causing the top of roller to cut it. So check the deck level there are adjustment devices on the mower to adjust, check for shine spots and for correct belt installment, and check roller wheel top for cuts or sharp spots, and check belt tension to see if it is to tight or too lose, also check that rollers spin free and there is not one stuck that could be heating the belt up too much, And last but not least make sure you are using the proper belt that is made for a mower fan belts don't last very long on a mower.
Jun 02, 2014 | John Deere 420,1020,2010,2020,2510,2520...
How to put a cutting belt on a craftsman RER1000?
cutting or blade belts our not that bad if you follow these two things.Idler pullys that are flat ,the flat side of the belt goes against it. If the pully has a v in the pully ,the v side of the belt goes in the v most times you can figure it out as a lot of mowers out there and the decks are different
May 07, 2014 | Garden
Cutting deck on my rancher ride on will not
ON some mower decks the pullies have small metal tabs/keepers that are supposed to prevent the belts from flying off when disengaged. I have replaced my belt before and went around the keepers rather than behind. this will add tension and will shread the belt. You might look and see if the belt is indeed on the pullies correctly and not around one of the pully tabs, I hope this helps.
Oct 28, 2009 | Garden
Blade belt pullys, need diagram, picture.
Need to know what Model # you have?
Try going to www.precisionope.com and put your model number in there to see if it can give you what you need.
Oct 02, 2009 | Garden
Craftsman 42 inch cutting deck riding lawn mower. I can not get the mower to to ingage. The belt appears to be tight and has not follen off the pulley.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Aug 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck belt need to no how to put the belt on
How to install a belt for a poulan riding lawn mower deck S#120403A001222 15.5Hp 38" 5sp
Jun 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Belt jumped off pullies
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
Apr 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 18.5 riding mower when I engage the blades to cut the blades turn But they do not engage NO Power.Blades Turn But Not enough to cutthe grass.
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
79 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
