Question about Briggs & Stratton Garden
7Hp OHV Briggs & Straton Craftsman Front Propelled Smokes
Engine smokes and uses oil even after cleaning blowby valve. Are valves allowing oil to get into cylinder? Whers do I start please?
  • 333 Answers
Sounds like it is the valve seats. However normally it will stop smoking after is runs for a while if that is the problem. Does it run good? Because if it isn't the valve seats then it is the rings. Or a big scratch in the cylinder wall. Then most of the time it will loose compression. If it isn't smoking real bad then you can get an additive to put with your oil that will make it stop, maybe? It is about ten dollars and you can get is at most autoparts stores. It will just take a couple ounces of it. Follow the directions for how many qts of oil you have. After you change the oil in the motor take a magnet and run it through the oil and see if there is pieces of the rings in it.
Posted on Jul 12, 2010
How much oil to fill 2003 7hp ohv briggs motor on snapper push . mower smokes after warm up . replaced case breather. could coil be the problem. haed to start when hot
Approximately 24 oz. Recheck the level you may have to add a little more. To much oil will blow in to the air filter if to full and cause smoking.
May 07, 2017 | Briggs Garden
Briggs and stratton 15.5 horse power over head valve
could be to much oil in engine are bad rings in engine or bad valve seals one of those three i would go with bad valve seals
May 14, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
22hp.zero turn sometimes smokes then stops.
The smoke could be caused by blowby around the piston rings. Pour a small amount of transmission fluid in the spark plug hole and turn the engine over several times. Check the plug for fouling. Also check the coil wire for spark.
Apr 15, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
White smoke
smell the oil and see if it smells like gas the needle valves don't seat and gas overflows into the crankcase if so change the needle and seat and change the oil run it without a load and the change the oil a second time
May 11, 2012 | Briggs Stratton IC Horizontal OHV Engine ...
LAwn mower smokes when It runs
adjust the valves to .008 on each valve to eliminate the smoking exhaust
Jul 07, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I have a briggs 24 hp twin v intek engine, started smoking last year with only 50 hours, now with a little over 60, it smokes like a steam train and uses 1 qt oil/30 min. Last week it fouled a plug, I...
Double check that the head bolts are properly torqued.There is a crankcase breather if stuck open could be drawing oil into the intake, and there is a valve stem seal on each intake valve that could be leaking. All this is assuming that the oil level is not over full. They will smoke like a banshee if they have to much oil in them.
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have briggs and stratton 5.5 hp motor model 12h702.And oil comes out of the breather.Could it be the valve guides or the rings. It smokes out of the breather hose and exhust a little.
It sounds more like badly worn rings and/or a glazed bore. Provided bore is not badly worn, a bore hone and a new set of rings should solve the problem. While yuo have the engine apart, a valve grind and check/adjust of the valve clearances wouldn't hurt.
Sep 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
318 people viewed this question
Top Briggs & Stratton Garden Experts
John Trevino
wadingriver
wadingriver
Jim Parker
Jim Parker
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
