I need to wipe the hard drive clean of an acer aspire one. I need to install windows again, but it is an older version than currently installed, and will not allow an older version to overwrite.
    Scholar:
  • 135 Answers
When turning on your AspireOne hit F2 to enter the bios
from there go to the MAIN tab it look for system time
go all the way down to SATA mode and change it to IDE
..... mine was on AHCI but when i changed it, it showed my harddrive
Posted on Jul 12, 2010
  • 60 Answers
If you are trying to upgrade it wont work. You will have to do a clean install. Go into B.I.O.S., configure to boot from the C.D. Rom, insert the operating system's disk and do a clean install. It should work.
Good Luck+.
  • 61 Answers
You can do this with a boot disk if you have one, or a version of linux (my favorite way).
ACER ASPIRE 3750G 13.3", reformat.
when you turn the unit on hit Alt+F10. This will access the acer recovery partition from which you can restore. This is provided you didn't replace the Hard drive or wiped the drive yourself
Aug 02, 2011 | Acer Computers & Internet
When i try the acer system recovery it keeps coming up with an error that says windows could not install and setup with resume when computer restarts..restarts ands same box pops up? cannot get past that...
Have you tried booting to the system recovery again and starting it over? Otherwise you may need to wipe it clean and start from scratch. Download a program like Darik's boot an dnuke to wipe the hard drive clean (this will destroy all data on the hard drive, including system recovery data if that is saved on the hard drive instead of CD's.) Then try the system recovery again (if it's on CD's)
Jun 24, 2011 | Acer Aspire One PC Notebook
Purchased 160gb hard drive. After installation, I installed the Acer System CD Rev 1.0 and recovery CDs that came with the laptop. see op system and specs below, but after the core load, I updated to SP3....
It very well may be a BIOS limitation. How old is the PC/Motherboard, and what model? Also, Windows has a 137GB limitation without at least SP1, if I remember correctly.
Feb 26, 2011 | Acer Aspire 5002WLMi Notebook
I have aspire 4520 acer laptop.after formatting c drive and installing xp sp-2 ,audio device is missing,kindly advice the solution?
You need to install the support programs for your laptop motherboard. These are also called your "laptop driver software" which is usually shipped or packaged with your laptop. In this CD or DVD Installer, all hardware devices must be well supported by their compatible software drivers.
Now look for the CD/DVD Installer and install the drivers.
Jun 09, 2010 | Acer Aspire 4520-5141 Notebook
How do I wipe out an aspire one netbook?
Use a Windows installation CD and re-install Windows; the CD version must match the Windows version on the Windows Product Code label on the bottom of your laptop.
You will also need to download the device drivers for your model laptop from the Acer WEB support site, make sure the download the correct XP or Vista version of the drivers which matches the Windows version you are installing.
Apr 01, 2010 | Acer Aspire One PC Notebook
Acer aspire 5600. Did a system restore and the computer would not start the windows programme then stopped trying and comes up with 'ntldr is missing' and won't get past that. Any advice would be much...
Sometimes the only way to repair XP is to reinstall. You do not have to wipe your partition and start over. Just as with previous versions of Windows you can reinstall right over top of an existing setup. This has the advantage of retaining your installed applications, data and settings. You will lose previously saved System Restore Points but System Restore will begin creating new restore points again immediately following the Repair Install. You will need to reinstall SP2 and any Critical Updates from the Windows Update Site. Be aware that a Repair Install will leave your system vulnerable to the Blaster and Welchia worms. Do not go on line until you have enabled XP's firewall first. Then visit the Windows Update Site to patch your system It is always prudent to backup important data before you make changes to XP. There are two approaches. The first one should be used if you can still boot to your Windows Desktop. Simply pop the XP CD into the CD-Rom drive and select Install->Upgrade[recommended]. This will install XP overtop of itself in the same way as upgrading from a previous setup. However if your version is an OEM version then you will not have this option. If you do not see the option to Upgrade[recommended] DO NOT choose New Install as that will either overwrite your current setup completely or give you a dual boot setup. Also if you have an older version of XP and have upgraded to a new service pack you will get a message stating that a newer version of Windows was found and you will not be able to run the Upgrade.
1-Boot with the Windows XP CD and at the Setup Screen press the Enter Key
2-You will be taken to the Windows XP Licensing Agreement. After reading the agreement press F8 to proceed
3-
The next screen gives you the option to do a fresh (clean) install or to repair the selected Windows XP installation. To run a Repair Install Press "R" at this time.
***CAUTION*** if you do not see the option to repair the selected Windows XP installation DO NOT choose the option to continue installing a fresh copy without repairing as that will overwrite your data and cause unrecoverable data loss.
Windows XP will copy the necessary files to your Hard Drive to begin the installation and will then reboot. You will see the message that informs you to "Press any key to boot the CD". Do not press any keys this time just wait a few seconds and the Windows Startup Screen will be displayed. Following this you will be greeted by the Windows XP Setup Screens.
When Setup has completed you should find all of your previously installed apps and settings are intact.
Feb 22, 2010 | Acer Aspire 5500 5570-2609 Laptop
I installed XP Pro, and now I cannot use my DVD drive to play DVDs
Windows XP doesn't come with the proper codecs to play DVD movies by default. You either need to buy a program with the codecs, or pay Microsoft for them. What I've found works best is to download the trial of WinDVD. It installs the needed codecs and you don't even need to use the program. So after you install it just use whatever program you originally wanted to use and you should be set.
(The older versions od WinDVD could be uninstalled while leaving the codecs behind, but the new version seems to remove them after uninstalling, so you'll want to leave it on the computer)
Hope that helps :)
Apr 14, 2009 | Acer ASPIRE 3680-2022 Notebook
Reinstalling Vista and Acer Tech
The restore disk should be available from Acer Suppport here https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer if they no longer support it then you should be able to get it from restoredisks.com
Feb 08, 2009 | Acer Aspire 5610-4648 Notebook
ACER ASPIRE M5641
Acer Aspire M5641
NVIDIA nForce 630i/7100
Intel(R) Core(TM)2 Duo CPU E4700 @ 2.60GHz
1. Go to http://www.nvidia.com/Download/index.aspx?lang=en-us
2. Download the latest version driver, extract to flash disk.
3. Connect your flash disk when windows said that driver is missing (before enter vista serial
number) and browse to "IDE/WinVista/sataraid" windows will choose the driver that it need,
install it
4. The process will continue as usual....
Nov 13, 2008 | Acer Aspire RC500 PC Desktop
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
