Question about Ovens
When I turn on my Jenn air oven an F9 message comes up - any idea how to fix
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F9 error in your Jenn Air oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it’s working. If it’s not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
F9 ERROR ON TIME SCREEN
F9 Door lock safety circuit on the power relay board sensed Recommended to replace power relay board
Oct 01, 2012 | Jenn-Air JGW8130A Electric Single Oven
My oven shows a f9-3 code how can i fix this short of calling a repair person
The F9-3 error code means that their is a problem self clean door lock system. Typically their is 2 switches that check the position of the door latch and even if it's open and not in self clean mode the switches are telling the computer the latch is closed. You should if fairly mechanically inclined be albe to find the latch behind the control panel and use the wiring diagram there and check those switches using a meter set to a low ohms setting and check for one switch being open (infinate ohms resistiance) and the other to be closed (zero ohms)
Good luck, i hope this helps
Gene
Jul 31, 2011 | Jenn-Air JJW8530C Expressions Collection...
Oven wont turn on and gives F9 message
I UNPLUGGED THE OVEN FOR 10- MINUTES, THE PLUGGED IT IN AGAIN AND HELD THE CANCEL BUTTON ALONG WITH CLEAN FOR 10 SECONDS. THIS CLEARED THE PROBLEM.
Feb 08, 2010 | Ovens
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Oven door won't unlock
I posted a message on 12/27 and since then I have contacted Jenn-Air again and as I mentioned above the two things they told me to do didn't work, so I looked at the schematic of the unit and there appears to be a motor that locks and unlocks the door. I have a service repair coming this Saturday and seems to believe the motor is bad. Trenatru are you getting an error message? I was told by Jenn-Air that there is a 6 yr. warranty on electrical parts so will try to keep you posted if that is the cause. If you havn't tried shutting off the power try that first. They said keep it off for a couple minutes before turning back on. If that try pushing on the door and hitting cancel twice. If those two things don't work, will let you know what I find out next weekend.
Dec 24, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
