Question about Hotpoint HTS16HBR Top Freezer Refrigerator
HOT POINT FRIDGE - FREEZER DRIPS WATER
I am having the same problem as georgelwslws. Hotpoint Model CTXY14CMDRWH. For the last five months, the freezer drips water. The fridge is at least 20 years old. When the fridge was in the off mode, I unscrewed the freezer floor and found water and ice. The water seems to drain into the fridge section before it starts freezing again.
  • 4,070 Answers
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Posted on Jul 12, 2010
How do I fix a hot point fridge freezer FFUXL 4DK displaying error code 7?
Hotpoint Refrigerator Error Code E7 = Environmental temperature sensor fault
There may be a number of things affecting the temperature in your refrigerator if you see this error code displayed
Jul 22, 2016 | Refrigerators
Water drips form on a basket sort of thing toward the back of the refrigerator. It drips so badly that I have to use a water vacuum to remove it. What is causing it? There doesn't seem to be a drip...
Most likely your defrost drain hole is plugged and needs to be cleared out, if you remove the back panel of the freezer you can poor hot water and then soak it up until the hole is clear. It takes many tries, like about 20 with very hot water. Start by disconnecting the power, removing the 2 screws on the bottom of the freezer, pull up the bottom and remove, It may be stuck do to the ice, Remove the 2 screws on the back wall and pull it toward you disconnecting any wires. Under the aluminum radiator looking thing and under the ice there is a drain hole that needs clearing..
May 17, 2011 | Hotpoint Refrigerators
Hotpoint model CTXZ1D1BBRWW has water collecting in the bottom of the fridge under the produce bins. I can not see any water running down?
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Apr 14, 2011 | Hotpoint Refrigerators
Hotpoint RFA70 fridge freezer - refrigerator drain blocked. Have tried boiling water; bleach; p;unging and poking. Defrosted a month ago fixed problem but is back again.
I just cleared a blockage in ours using about 6 drinking straws all attached together ( squeeze end and push about 30mm inside the next one) a small funnel insulation taped to the end and pushed right down the hole until it stops. Then pour hot water into the funnel until it clears. Remember to keep the funnel as high as possible and the hot water being poured in will push any cold water back up the tube, melt the ice and clear the blockage.
/uploads/images/5_31_2014_3_08_17_pm.jpg
Nov 11, 2010 | Hotpoint Refrigerators
Water drips down from Freezer. The water is coming
Since you said the water supply is shut off, the likely culprit is a clogged drain tube that connects the defrost tray to the water collection pan for evaporation at the bottom of the fridge.
The source of the clog is usually either mold growth or more likely, ice build up. Regardless of which, if you access the defrost heater in the freezer section, you can thaw ice that has collected in the tray and if needed, use a turkey baster to direct a hot stream of water at the point the hose attaches to the tray and treat the hose for mold, below.
Once cleared of ice, mix a small amount (5 or 6 oz) of water and 1/2 to 1 ounce of bleach and direct down the tube to kill any mold / growth. Be careful not to use to much or overflow, as clean up will be difficult due to the bleach mixture.
The next thing to do (if icing up) is to determine why. A careful check of the defrost circuit should be done. Otherwise, you'll be doing this over - and it may start to affect the temperatures in the frozen and fresh food sections of the fridge.
I hope this helps!
Nov 05, 2009 | Air Purifiers
Hotpoint 18.2 cu ft refrigerator -water pooling on the floor
Was it the tubeing that drains the defrost water that you cleaned. Did you clean it at the top where it would be stopped up with ice. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If not
Aug 15, 2009 | Refrigerators
Water drips from bottom of fridge. It happens
look in the bottom of the inside of the freezer, you probably will see ice buildup.You have to clear the drain which is stopped up at the bottom of the panel that covers the freezer evaporator.Every 8 hours the drain receives water from the auto defrost and needs to go in the drain, if drain is stopped up it freezes and eventually runs out the front
Mar 25, 2009 | Hotpoint HSS25GFP Side by Side...
Sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
319 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
