Question about Sony Playstation 3 (PS3) Console
My Playstation 3 console won't turn on or eject. The power button is red when I touch it turns green then beeps and turn yellow then flashes red constantly does anyone know what I need to replace?
    President:
  • 1,139 Answers
Unfortunately this is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3
Hope this helps
Posted on Oct 16, 2010
When turning on my console it wont fire up or eject the disc that is in the machine the Standby light flashes, beeps and then nothing ?
Maybe you have the "yellow light of dead"
You should let it repair, your console is broken.
try putting it in recovery modeHow to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
Flashing red light will not eject game
if you turn it on, and it goes green then yellow then beeps 3 times and flashes red, then your ps3 has overheated and been damaged. you can fix it with the heat gun trick, http://www.youtube.com/watch?v=4_Ic1_TY-GU
but it will only break again.
try flipping the switch in the back, then hold the eject button while you flip the switch back on, that should eject the disc.
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Mid game my console beeped and shutoff. Now it wont eject disk or turn on at all. Light goes Green, Yellow then flashes Red
your PS3 overheated, what you need to do is remove the power cable and hold the power button for 5 seconds to make sure that there is no power left, then plug it back in and press the eject button hold it down, it will power up and eject disk, if that fails, you need to RMA your ps3 to sony or you can try and return it to vendor with the game case or dvd case of the disk that is stuck they should replace both
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
This most likely is Power supply issues, try replacing power supply.
Aug 28, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
