Question about Whirlpool CAM2752KQ Top Load Washer
I have a Whirlpool commercial washer, Model CAM2752KQ0. The washer will go through the wash cycle but will not spin. The problem is not the switch. What else can it be
  • Whirlpool Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineI have a Whirlpool commercial washer, Model - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jul 12, 2010
My washer won't spin or drain, but it will wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jul 11, 2010 | Kenmore 22422 Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool super capacity commercial washing machine
Sounde like a bad lid switch . With no model number , can't help you further .
Sep 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool CAM2752KQ Top Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De
