Question about Singer Sewing Machines
1892 singer sewing machine.. how to thread it (specifically the bobbin)? seems to be oscillating shuttle type
  • 980 Answers
Is it a round or long shuttle?.
Posted on Jul 14, 2010
Singer Futura XL-580 thread tangles on underside.Machine makes a loud "clicking" sound.Was doing free motion quilting and got a jam. Changed needle,changed bobbin,and rethreaded both top and bobbin.
Sounds like there might be some thread stuck in the bobbin shuttle area. Refer to the users manual for your machine to see how to disassemble the bobbin shuttle and race to check for thread. It would be a good idea to put a drop or two of sewing machine oil on it while you have it apart.
Aug 21, 2017 | Singer Sewing Machines
I have a singer 128 vibrating shuttle tredle sewing machine. It hasn't been used for decades. I have it threaded (bobbin & needle) but it won't stitch. It doesn't seem to be picking up the bobbin thread.
Have you cleaned the bobbin area? The thread tension?
Any machine that has set for more than a few years will need a full service and cleaning; they just gum up.
Mar 17, 2015 | Singer Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise...
try changing the needle
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Sep 30, 2010 | Singer Confidence 7467 Mechanical Sewing...
Threading up a bobbin in a singer 560 sewing machine
I'm guessing it's probably the same as mine (8280). This is what the manual says: "Hold the bobbin case with one hand, insert the bobbin so that the thread runs in a clockwise direction. Pull the thread through the **** and under the finger. Hold the bobbin case by the hinged latch and insert into the shuttle." It's hard to describe, but if you've sewn before, it should come back quickly. To be more specific, hold the bobbin case in your left hand, insert the bobbin so the thread is coming up from underneath, pull thread through the **** and into the part where the hole is. If you slide the thread around, it will fit into the slot in there. Pull the latch out and insert it into the shuttle.
Hope this helps.
Mar 27, 2010 | Singer Sewing Machines
Bobbin Case cannot be replaced properly
Make sure there is no thread wrapped around the bobbin case retaining pin in the locking groove. This pin is part of the shuttle hook. I am assuming this is an oscillating machine and the bobbin case is removed to install the bobbin.
Jan 24, 2010 | Sewing Machines
Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Dec 29, 2009 | Singer Sewing Machines
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Sewing Machines Logo
100 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
