Question about Kenmore 95002 / 95004 Electric Kitchen Range
Left front element does not heat - Kenmore 95002 / 95004 Electric Kitchen Range
  • 10,865 Answers
Hi. Chances are it is shot and needs to be replaced. You can order a new one at searspartsdirect.com
J.
Posted on Jul 12, 2010
I have a problem with our stove we replaced the fuse cause we thought our front left element heated very low and it still did not work the element still heats low
Yes if it heats at all it would not be a fuse.You do not advise the vintage or make and model so it is hard to advise. It could be the element control or the element that is bad/defective.
Dec 11, 2014 | Kitchen Ranges
Will not start
It's very likely that your heating element is shorted and will need to be replaced. Unplug the dryer and remove the lower front panel. There are 2 spring clips between the upper front panel and the lower front panel. Use a flat screwdriver and slide it over these clips and then pry these clips down to unclip them so that you can hinge the bottom panel down and then off. The heating element is in the bottom right corner inside the silver heating canister. There is one screw coming in from the left holding the element inside the canister. Remove the screw and remove the front panel of the heating canister. Disconnect the wires to the element and then the element will pull straight out. Here is a link to the part.
http://www.repairclinic.com/PartDetail/Heating-Element-Assembly/3387747/525502
Thanks
Jun 21, 2011 | Kenmore 63942 Dryer
I have a Whirlpool Electric Dryer that is running but will not heat up. I suspect the heating element has failed. The Model Number is LEQ9508PW1. Please detail for me the location of the heating element...
unplug unit remove front lower panel . on the right side you will see the heater box element is held in place with a small screw on front left side and friction hold outer housing with hand and pull out element with a pair os pliers.
Aug 02, 2010 | Whirlpool Dryers
The main burner (left front) only heats on half the circle.
Your referring to an electric range I'm assuming. In that case the heating element is only heating to a mid-point then stopping. This typically means the heating element is burnt or is partially burned out. The element is usually user replaceable and requires the old one be unpluggude and replaced with a new one. You'll need to get the element from the manufacturer.
Apr 21, 2010 | GE Cooktops
Whirlpool dryer not heating up checked heating element have continuity arcroos coil connectors
Check the thermostats. Unplug one wire and test for continuity across the thermostat terminals.
Jan 03, 2010 | Whirlpool Dryers
How do you replace the heating element in a Maytag PYE-2300
Unplug the dryer cord.
Use a putty knife to release the 2 spring clamps holding the top lid to the front panel. They will be about 2 inches in from the right and left sides where the top meets the front.
Raise the top lid and fold it towards the rear of the dryer.
The heating element will be in the back left corner.
Remove the hi-limit thermostat on top of the element. Remove the element retaining screw and remove the element.
You should replace the hi-limit thermostat also.
Dec 14, 2009 | Maytag Dryers
Left front element transfering heat to frame. Top side and front of frame are very warm to touch. Should I refrain from using that element until it can be check? Is there a danger of electrical fir
There is usually a door seal around the oven door if its gone or out of place this is most likely the problem. 1 other thing is that Insulation can be moved around (not meaning to offend just stating facts), insulation can be moved around by rodents, or if it happened to get wet it could shrink.
If either of these help you undersatnd and find your problem please rtate me as high as you can. Thank you for using fix ya.
Apr 28, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Maytag Atlantis dryer no heat
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Aug 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Accessing heat element
You get into the unit from the top. Use a putty knife about 2 inches in from the right and left in the seam on the front of the unit and push in on the spring clip then lift on the top. After that take the front off and work your way down. The heating elements are on the bottom right when facing the front of the unit.
Jan 09, 2008 | LG DLE5932W Electric Dryer
Kenmore 95002 / 95004 Electric Kitchen Range Logo
62 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
