Question about Frigidaire Refrigerators
Why is my freezer leaking water all under neath?
  • 10,865 Answers
Hi. Chances are the evaporation tray near the floor is dusty. Remove the grill, clean the tray and your problem should be solved. J.
Posted on Jul 12, 2010
Leaking under neath heating unit but it's not the hose but a little white knob underneath unit
ac drain . There could be a blockage in the AC drain pipe that runs under the car. This can usually be unblocked with compressed air they jack up vehicle takes 30 seconds to fix with vehicle hoist.
When it blocks up the AC unit builds up with water and leaks clear water inside the car. if it was green water it would be the heater core leaking coolant.
Mar 20, 2016 | Cars & Trucks
Water keeps leakingon floor from under neath
check drain pan..... also make sure water not comingfrom inside fridge
Aug 31, 2014 | Maytag MSD2456G Side by Side Refrigerator
Rv leaking water under neath
The statement is extremely vague. Is it a travel trailer or a motor coach? Motor coach could be dripping condensation from ac while in use. Is it fresh water and only leaks when connected to a hydrant? Does it only leak when sewage is dumped into the black water holding tank? In short, you must determine under what condition the unit is leaking. Then narrow down where it is leaking from and then identify the failed part. RV manufacturers do not publish plumbing diagrams so it is all visual in the diagnostic process.
Jun 16, 2014 | RVs
Frigidaire refrigerator side by side model FRS26ZTH water on floor of freezer
pull it out from wall there is a tube that runs down to drip pan under neath also check door seal by closing door and sliding acard between seal and unit if loose or gap it will make unit sweat
Jul 13, 2012 | Frigidaire Refrigerators
Ice maker doesnt work anymore
the cause may be several things like bad water valve . no air flow over ice mker cause is no fan in freezer . tempt in freezer is abofe 15 deg . / some times cleaning the coils under neath and make sure the fan down under is going also. . and if all else failes the ice maker may be bad . hope some of thes will help .. ****
Feb 23, 2010 | Refrigerators
Water sometimes appears under neath the refrigerator
Several things could cause this. A leak in the condesate collection tray near compressor, a leak in a water line or a frozzen over or blocked drain beginning inside freezer.Here is a link that may hl explain a ltle of what I am saying. Click Here=> Sea BreeeTip's then scroll down to the bottom and read and watch that short clip. If you have questions ask. I would likwe to help you solve his, Sea Breeze
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Feb 12, 2010 | GE Refrigerators
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Washing machine pouring water out on final spin
The rubber pipe under the machine is usually parished......
Feb 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Refrigerators Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
