Question about Maytag MSD2732GR Side by Side Refrigerator
Maytag side by side ref/freezer Mod# MSD2732GR, the ice maker stopped making ICE, with the full limit switch in the down position.
  • 4,070 Answers
Is the freezer cold enough? Should be close to 10 degrees. Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start. If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Posted on Jul 12, 2010
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
Icemaker not working
You write very well for a child and a lot better than many of the adults that post questions!
It worries me that you say the fridge started making noises. Compressors make noises when they are failing. However, depending on what type of ice maker you have, chunks or crushed, it might be that. You can usually get to the ice maker system by removing a few screws behind (if in the door) or at the side of the unit (if inside). Look for ice build up in a big block and remove it with a hair dryer.
Anything more that that, you will need a service engineer. All the manuals are available online if you Google them.
In the meantime, freeze ice in the freezer. I live in Canada and it is minus 11'C with the windchill today :>)
Maytag MSD2732GR Google Search
Dec 12, 2017 | Maytag MSD2732GR Side by Side Refrigerator
Our ice maker is not working. It fills up with water, but the "teeth" dont completely turn causing the ice to pop out. It's like they get stuck in the final step. I recently put in a new...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 31, 2011 | Maytag MSD2732GR Side by Side Refrigerator
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Our kitchen and pantry were flooded because the icemaker wouldn't shut off. My husband had to unplug the refrigerator to stop the water from pouring out
That is a rare happening but the solution is inside the ice maker itself. Click Here=>MSD2732GR Ice Maker Parts Break Down Part 13 is the Click Here=> 627985 Ice Maker Thermostat and sometimes it is just less expensive to replace the complete Ice Maker=> Ice Maker
Assembly
Simply unplug the ice maker from inside the freezer section rear wall until you can replace the part or ice maker. If you have more questions feel free to ask here or my through my web sites. Thanks, Sea Breezesea_breeze_15.jpg
Appliance 911
Dec 08, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker stopped working
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Jun 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Maytag MSD2732GR Side by Side Refrigerator Logo
82 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
