Question about LG LWHD1800R Wall/Window Air Conditioner
Why does my LG window ac unit freeze up and leak water?
  • LG Master
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningWhy does my LG window ac unit freeze up and leak w - 2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jul 12, 2010
    Scholar:
  • 66 Answers
First check filters and evaporator coil. If they are clean, Remove the unit from the sleeve housing. Take it outside and clean all of the fins with a garden hose. Likely this alone will solve the problem but if it does not, the unit will to have refrigerant added. This means a service port will need to be installed and probably is beyond the means of do it yourself. However piercing valves come with all that is needed and instructions. In many places a can of r-22 can be purchased for about 13 bucks. Really it is impossible to get the right charge without proper tools. But if you want to take the chance of trying you can add refrigerant until you start seeing the evaporator coils sweating all the way to the bottom. Bear in mind that if you err with charging it is better to under charge than over charge. Over charging the unit will damage the compressor.
4 Suggested Answers
crouchdash
  • 83 Answers
SOURCE: LG 18000 ac leaks water in the front of unit.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Posted on Jun 05, 2009
dhj144
  • 80 Answers
SOURCE: my ac unit keeps freezing up on the pipes and
If you own indoor pets you will want to change the return air filters monthly like religously. You may also need to have the A-Coil other wise none as the evaporator coil cleaned manually. It is located inside the air handling unit inside the house somewhere. It could be restricting the air flow across the coil with daner and dust and/or deris. Sometimes it can be difficult to clean but with care and lots of elbow grease it can usually be done. Be careful not to bend the fins! Once this is completed and the unit still freezes up! Then you can be sure it is low on refrigerant 90% of the time! Cleaning the A-Coils is something you should do or have done anually!
Posted on Aug 22, 2010
okra123us
SOURCE: gold star ac window unit
window ac clicked during a thunder storm won't come back on.
Posted on Aug 01, 2011
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
What is the presure of the LG WINDOW AC compresser .we perchesed it in2005.last year we found that it was not cooling so we called AC man he said that gas has to be fill ,he did it .again this year also we...
If he is having to continually recharge the unit, the unit has a leak in it. The leak would have to be located before the cost of repair could be determined.
Feb 24, 2010 | LG Heat cool Window Air Conditioner
Icing up of unit
When you clean the Ac unit, Make sure to take the Unit completly out and clean both the condensor coil as well as the Evaporator coil.
If you are able to run the unit with it out of the window. See if there are any service ports connected to the unit (Guage hook ups), or any OIL spots where is looks dark, (Checking to see) if its leaking.
Wasnt sure how you cleaned the unit, So just make sure both coils are cleaned well with water, and make sure to avoid getting to much water into the Electronics.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 25, 2009 | LG Heat cool Window Air Conditioner
Lg lwhd1200fr air conditioner is leaking water inside, best ideas on how to solve this problem?
REPOSITION UR WINDOW AC. RAISE FROM FRONT ABOUT 1/2 " SO WATER WILL DRAING DOWN TO CONDENSER OUTSIDE.
Sep 12, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
Excessive Leak
Remove the plug and tilt the AC slightly downward on the outside so the water will flow outside where it is supposed to go. Thanks, Sea Breeze
Aug 29, 2009 | LG Heat cool Window Air Conditioner
We have 1 ton window ac and its not cooling properly and forming ice, also its not draining out water properly
the fact that it is not draining could be the problem with it freezing up. you might have to pull it out of the window, pop the cover off and clean the drain pan so it will drain properly. also make sure the unit is level . if it still freezes up once draining properly it is probably low on charge.
Aug 27, 2009 | LG Electronic Window Air Conditioner
My lgl1006r is leaking from the back of ac is that normal????
This is completely normal for a window a/c unit. The purpose of the leaking is to leach the humidity from you home in the summer. When the house is hotter the air is inherently more humid. As warm air is passed over the condensors in the unit it turns into water and should drip out of the back of any air conditioner unit. It essentially turns into distilled water. Not a problem and don't worry! Enjoy the air!
Aug 02, 2009 | LG L1006R Wall/Window Air Conditioner
LG 18000 ac leaks water in the front of unit indoors.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Heating & Cooling Logo
830 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
