Question about Craftsman Garden
KEEP BURNING UP MOWER DECK BELTS - Craftsman Garden
  • 43,501 Answers
Check the tensioner to see if it is placing proper pressure on the belt and holding it tight enough...also check the pulley alingment... if one is out of alingment it will eat belts...also check that they all spinn freely and there are no bad bearings...
heatman101
Posted on Jul 12, 2010
3 Suggested Answers
  • 246 Answers
SOURCE: Mower deck does not engage
Hello:
>>Check the Voltage from the Stator/Charging Coils.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>A Bad Stator/Charging Coil will Cause the Problem you Described.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 850 Answers
SOURCE: I've got a 21hp lt1000. The mower deck keeps
check the idler bearing & adjustment awell as the pully alighnment
Cheers Rob
Posted on Aug 16, 2009
My green craftsman mower has the 20.5 hp in i t starts right up but after clutch release it fails to go forward or backward ,,,i have the cutting deck off i am hopeless
So, how many belts did you remove to get your mower deck off? There are two belts on the mower, one drives the mower deck, the other makes the tractor go fwd & reverse.
Jan 27, 2018 | Craftsman Garden
I have a huskee lt 4200. I keep buying deck belts for it but it keeps eating them up. The tensioner pulley is engaging but the belt flaps around real bad. Ive replaced cable. Caint figure it out.
Clay it may be time to replace the pulleys,including the engine pulley, check all bearings and blade spindles for wear and free movement and if the tensioner is on an arm lube the arm so it move freely.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why am Breaking So Many Belts on My Mower
http://www.tractorforum.com/f166/burning-up-deck-belts-21199
Craftsman lawn tractor breaking belt after each use
Why Does My Yard Man Mower Keep Destroying the Belt That Is on the Deck to...
Jun 05, 2016 | Garden
Why does my Troy Bilt Pony Mower deck keep running after it is disengaged
-The belt is too tight. It should be free when the engine is running.
-Adjust it. It'll take care the problem. (I'll say it'll need about 3/4" to 1 1/2 clearance)
Good luck
mai
Sep 01, 2014 | Troy-Bilt Garden
Mower stalls
make sure belts arent around the guides to keep the belts on.
does it smoke or make any other noise
why did yu change all the parts
Jul 09, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I am burning up deck belts on a 2 year old John Deere LA 105 mower
make sure the pulleys are free the check the arbor brakes
Apr 03, 2012 | John Deere Garden
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
I have a troy bilt riding lawn mower and I followed the diagram on replacing the deck belt and it seems to keep rubbing something and burning the belt to smithereens. this has happened twice. have a brand...
Depending on which side of the belt is being rubbed is where I looked. If it is rubbing on the inside, I would suspect one of the blade being bound up and not turning.
If it is on the outside I would suspect something to do with the shield.
Jun 17, 2011 | Kitchen Ranges
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Garden Logo
674 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
