Question about Sony Playstation 3 (PS3) Console
Loading.. I am having a problem when trying to load the ps3 home menu area.. when i connect to my hdtv it just says no signal.. however when i insert a game the game loads up fine. I am guesing there may be a problem with loading the home software.. can anyone give me any information in regards to solving this problem? I have tried my HD cable on another playstation and it works fine.. thankyou
    Problem Solver:
  • 5 Answers
Its broken dude
Posted on Apr 22, 2008
Ps3 not loading disk
Here is how you can fix the not loading/reading disk on PS3.The problem is with the sensors under the Blu-ray drive that are not making contact with the base of the system. So, the first thing to do is open the PS3. Then, you slightly put pressure over the area where the disc loads and after this your disc should begin recognizing all discs inserted and will load a disc without any problems. This should fix your problem. If this does not fix your problem, you will need to send your PS3 to Sony to have it repaired by specialists.
Feb 03, 2011 | Video Game Consoles & Games
When i try to connect my genius hs-03u's to my ps3 it doesnt work is there any way to make them connect
First, examine the connection receptables on the PS 3. For example, inserting the head set pin into wrong PS 3 connection receptable would not produce any sound discussable.
1. The PS3 device has several connection receptacles either for video audio output or video audio in put.
2. Video audio out put only gets sound and movies out of the PS3 device to be projected on to another device, e.g. projector, TV screen or Any out put devices.
Note: You solution is to connect the headset to the out put indication area keeping in mind not to connect to the Video receptable, else would be trying to output video signals to the headset.
Caution: You do not want to connect the headset pin to the Video Audio Input receptacle areas, because, you would be trying to send signals into the PS3 device rather than get sound out.
Important Notes;
Getting signals out of a device like PS3 is inserting the headset in this case, pin connector would be inserted in the INPUT Area; keep in mind your are tryinng to hear sound, SO connect the HeadSet PIN to AUDIO reception area on the PS3 device
The same techniques is achievable for all equipment requirign connection.
REMEMBER TO PHYSOCALLY LOCATE THE INPUT to OUTOUT area on the device.
Give the following proccess a try.
contact the manual of the PS3 device refering to the device connectivity chapters or
Systems diagnostic or malfunction chapters for technical material when required.
Dec 02, 2010 | Genius HS-03U Headset
When I deleted home on my pS3 I got corrupt files
  1. Insert the PlayStation 3 memory card that has the corrupt file into the memory card slot of your PlayStation 3 console.
  2. Step 2 Turn on the PlayStation 3 without a disc in the console or with the loading lid open. A menu screen will then appear on your television.
  3. Step 3 Scroll through the options of the main menu using the down button on your directional pad and press the "X" button when you get to the "Browser" option.
  4. Step 4 Click on the icon that shows the memory card that you inserted by pressing the "X" button. You will now be able to view all of your memory card files. Locate the corrupt file and click on it with your "X" button.
  5. Step 5 Scroll through the list of options that appear and select the "Delete" option by pressing your "X" button. The file should now be deleted. Restart the PlayStation 3 and go back to your memory card to make sure the file was deleted.   NOTE WITH THIS IT WORK PROPERLY....
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not loading disc
can you play Blue ray Movies ? if not u will need to replace the Laser
Mar 20, 2010 | Sony Playstation 3 (PS3) Console
How to play blue ray dvd
Insert the Blu-ray disc into your PS3. Start up our PS3. Connect your controller. Using the controller, move along the cross menu bar to the Video option, and you should see the movie listed as an icon just like a game would be. Select it and it should load and start playing.
If you are having issues with it loading up, there may be a conflict with the console and the DVD region. For example, you can't play a DVD from Asia or Europe on a North American PS3.
Good luck.
Feb 19, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 freezes before loading up the home screen
if it's hard drive has a lot on it it will lag try cleaning out old saved games and music it will speed up.
Aug 15, 2009 | Sony Playstation 3 (PS3) Console
Ps3 game loading
unfortunately your bluray laser has probably failed. the diode burns out quickly on these older units. call sony they charge 150 or send it to me for 100..24hr turnaround
Oct 31, 2008 | Sony PlayStation® 3 (60 GB) Console
PS3 Home Menu
you can change the system settings to boot to disc when turned on. also if you don't see an icon for your game after you've inserted it, your laser may need to be cleaned or replaced.
Jul 30, 2008 | Sony Playstation 3 (PS3) Console
Game wont load on ps3
i had this same problem and the solution to mine was that my ps3 was in my garage and it was too cold in there for the system to operate so i moved it into the living room where it was warm and it eventually began to work
another solution is to just restore the system and then reinstall all of the updates
Jul 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
