Question about Vatical Entertainment Seadoo Hydrocross 2001 for Nintendo 64
Can u hot wire a 1998 seadoo - Vatical Entertainment Seadoo Hydrocross 2001 for Nintendo 64
Why wont a1997 Seadoo will no turn over ?
Could be a bad ignition switch grounding out the ignition, loose wires, bad ground. If it will not even turn the crankshaft over, then I'd check connections to the battery, to the 'ground', to the block/head/?? and make sure the wires on the back of the ignition switch are snug in place. Does it have an 'occupant' safety switch that will kill the engine if you fall off? That may need to be checked also.
Jul 22, 2014 | Rareelectrical SEADOO STARTER GSI 718cc...
Why after I flipped my seadoo and got water in the motor, it wont stay on without pressing the start button, why? how can I fix this? The seadoo is a 1999 xp
I would say that you shorted out the item on the other end of your start switch due to it working backwards. Check the continuity of the wires from switch & check the switch.
Jul 21, 2014 | 1999 Chevrolet Silverado 1500
Seadoo
I'm guessing you are talking about a PWC Seadoo. :-)
But you need to check the lanyard switch. There are two wires to the switch, the switch only connects the two when the lanyard is in place. So if you can locate the connector under the hood, just jump the wires together to check the switch wiring.
Note: You can not operated the PWC on the water with the wires jumped, it's against the law.
May 25, 2014 | Video Game Consoles & Games
Half speed at full throttle
what kind of jet ski we talking about year make model
Jul 06, 2012 | Sport & Outdoor - Others
2003 seadoo challenger. how do you adjust the trim to keep the boat from hopping or bouncing?
To stop the bouncing,you need to trim in or down.Adjust the weight on the ski forward.The best site for seadoo is seadooforum.It will solve any and every problem you ever thought of for Seadoo,s.Hope this helps
Jun 15, 2010 | Boating
Sea doo jet ski won't get full throttle. It idles fine but once you hot gas it regarding up and down
I am not sure of the model that you have,so its a bit hard to help.If you have a seadoo and you want great help,I would go to seadooforum.Its the best site with really good,and also total knowledge of all things Seadoo.I have one also.The help is unsurpassed.I have a seadoo also.Hope this helps you
Feb 03, 2010 | Sport & Outdoor - Others
Vatical Entertainment Seadoo Hydrocross 2001 for Nintendo 64 Logo
123 people viewed this question
Top Vatical Entertainment Video Game Consoles & Games Experts
James Wishart
Are you a Vatical Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
