Question about Hoover F6020-900 SteamVac Upright Vacuum
How do you remove brushes and clean under the cover?
    Problem Solver:
  • 4 Answers
I too have this machine. On this particular model the brushes are not removable like on the newer versions. You can either purchase a "cleaning wand" from Hoover OR create your own as follows: Simply obtain a pendaflex hanging file folder (legal size) and remove the metal rods. These rods work exactly like the Hoover wand they try to sell you. They are quite flexible and easily slide thru the clear plastic openings at base of cover. The hooked ends work wonders in removing furballs, hair and other debris that gets trapped under the cover.
Posted on Sep 26, 2010
Is there a more efficient way to clean the brush assembly on the max extract dual v other than running the assembly under water? The bristles are loaded with carpet fuzz and remains of doggy doo
Following is the procedure for removing the brushes.
  • Your cleaner is equipped with removable brushes. Follow these directions for changing brush assemblies or for easy cleaning. How to Remove To prevent possible leaking, remove Clean Water Tank and Dirty Water Tank. Set tanks aside. With handle in upright position, tilt cleaner back until handle rests on the floor. 5.3 Grab brush assembly and pull firmly.
  • The brushes can be cleaned under running water. ! CAUTION ! To reduce the risk of injury from moving parts, unplug cleaner before servicing.
See page 17 of the link manual for the details
http://hoover.com/file/594
Dec 10, 2015 | Vacuums
I would like to remove the clear cover over the brush bar on my Dyson DC-28 so that I can clean it. It's filthy and I cannot clean it with the brush bar in place. Is it possible to do this myself?
Hi there, it's Jack at Dyson.
DC28's cleaner head is a complex assembly which is not engineered to be dismantled. We'd advise against attempting this - any damage caused would not be covered under your Dyson warranty.
If you'd like some guidance on maintaining your DC28, please email askdysonUS@dyson.com and someone will be in touch as soon as possible.
Nov 23, 2014 | Dyson DC28 Animal Airmuscle Vacuum Cleaner
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The belt is not turning the brush bar when in the carpet cleaning position
DC7s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt2_bing.gif is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available oneBay2_bing.gifreasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you haveaccessto such tools, and feel confident to tackle it, it's probably time tocallDyson or aVacuumrepairer.
Jun 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
It makes a very loud noise and doesnt pick up much
When they make noise like that there is usually an issue with the drive system (the belt and roller brush). I would try cleaning off the roller brush and putting a new belt on. You can access the roller brush and belt by turning the vacuum over so the brush faces up. There is a cover plate over the roller brush which can be removed by removing the (4) phillips screws. with the cover plate off, you can remove the brush and old belt. clean the brush off really good and put it back with a new belt. This is normal maintenence for this model and should be done every 6 months.
You can get the replacement belt here:
http://www.vacbelts.com/bissell-powerforce-belt.htm
Oct 24, 2009 | Bissell 6594 PowerForce Bagless Upright...
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Brushes don't turn
I Had the same problem, The brushes are operated by water pressure. Under the machine were the brushes are is a white peice of plastic pull this out and try cleaning the screen. I found this when I removed the cover and lubricated the gears at the brushes, If that does nto work you will have to remove the turbines and lubricate.
Dec 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 | Vacuums
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Hoover F6020-900 SteamVac Upright Vacuum Logo
311 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
