Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
Water is not working
Just ice maker is working,i opened the back plate and a circut board was there ,when i press water dispenser i feel a little click back there but not sure what to do,
  • 4,059 Answers
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem.
If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Jul 12, 2010
The fan at back does not come on. The fridge make a clicking noise, The fan tries to run... Also it does not pump water anymore. It does make ice
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Ice maker not functioning or producing ice cubes
  1. Check connections
Check all hose connections to ensure that water is being transmitted through your appliance and there is no frost build up.
  1. Feeler arm
Double check to make sure your feeler arm is not stuck or that ice cubes are not blocking the feeler arm's motion to produce more ice.
  1. Ice maker heater
The heater may be stuck on. The heater comes on for 1-2 minutes to break cubes free from mold. If the heater stays on too long ,the ice maker will get hot and stop making ice. Carefully feel around the ice maker mold; if it is hot to the touch, the heater is on. This indicates that the ice maker is jammed, and it is better to replace ice maker than to try and repair it.
The water valve supplying the ice maker is a key component of the ice-making system. When the ice maker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. When this part is not operating correctly, a repair/replacement part may be needed. Refrigerator Repair Help Troubleshooting and Parts
Aug 16, 2014 | GE GSS22JER Side by Side Refrigerator
Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
May 07, 2014 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Frigidaire MN: GLHS68EJW0 SN: 4A81216798 When door water dispenser is activated, solenoid for the door AND ice maker both open, the same is true of when the ice maker call for water, originally tried...
Sounds to me that your=> 241708306 Dispenser Control Board has a broken connection and causing more that one function to happen at one time. I would also check all plug connectors where they run most times behind the kick plate at base of refrigerator. A very little water on that plug will cause problems like this also. There is a short circuit or two circuits wanting to work at the same time. I can answer more questions HERE or on Fixya, Thanks, Sea Breeze
Aug 30, 2011 | Frigidaire Gallery GLHS68EJ Side by Side...
Our icemaker cannot make ice so we were using small ice in the ice dispenser. Now the ice dispenser does not work. When we first started having trouble with the ice maker we immediately changed the...
Both of those are controlled by a voltage signal sent to the back and rear near floor of the back of your refrigerator. The part is a water control valve. When you press the dispense water button the valve if not defective will open and allow water to travel through the bottom fresh food section water reservoir to the cup. When the ice maker dumps fresh cubes to the tray to store foe dispensing ice it also opens the valve for its side fore just enough time to refill the ice maker. Then the ice maker waits until it senses frozen ice and begins the cycle by heating elements below it to loosen the cubes to begin the cycle again. So get someone to unplug the side on pack and put the probes of a multimeter into each female side and press dispense, you should see 120 volts there. If not the dual water control valve needs replaced. Part Number 4389177
Sea Breeze
Jul 15, 2009 | Refrigerators
Water dispenser not working but ice maker works
It could be the water valve located on the back, lower left corner of the freezer. On the outside. It's fairley easy to test. Just swap your water lines around. If you get water from the door then you need a knew water valve. If not then it could be the circut board in the dispenser. You will have to slide the face off of the dispenser. Hope this helps.
Jan 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Electronics on the blink
there is a circuit board in the back right side embedded in the unit has about 6 screws holding a cover plate this ill need replaced part # WR55x10552 you can look it up at www.apdepot.com
Aug 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool refrigerator water dispenser not working
My older whirlpool side by side refrigerator has stopped dispensing water. The icemaker works fine, and I have adjusted the temperature a week ago so I don't believe the line is frozen. I do not hear any noise when the dispenser is pushed down, and feel that is where the problem is. The line is clear on the bottom of the fridge behind the kick plate, but water does not come out freely when I disconnect the couplings...
Any advice?
Jan 17, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice and water dispenser not working but light on constantly
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these... http://www.acehardwareoutlet.com/(a1q3xi45sxgfbzm0qejhei55)/ProductDetails.aspx?SKU=3115672
Jul 31, 2007 | Maytag MSD2436GR Side by Side Refrigerator
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
249 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
