Question about GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
Neither side is cold and it is getting power. The
Neither side is cold and it is getting power. The controls at the top of the refrigerator side do not respond.
  • 478 Answers
This is most likely a control board. If you remove the back coverplate you can inspect the board.
If you look at the bottom left you will see a plug with three wires one L1 one Compressor, one defrost.
Unplug from wall put a jumper from L1 to COMP, plug in the compressor will come on if all else is well.
Posted on Jul 12, 2010
Fridge side not getting cold
I think its low refrigerant gas issue ...need to top up refrigerant
Jul 25, 2016 | Refrigerators
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
May 02, 2012 | Kenmore Refrigerators
The top half of my fridge and freezer are not cooling. Its a side by side unit and it is cold at the bottom. ??????
The evaporator fan motor has gone bad.....or the control board has gone bad and the fan is not getting power.... check for power at the fan and if there is power change the fan motor... if not then change the board...
http://www.repairclinic.com/PartDetail/Evaporator-Fan-Motor/1174059?modelNumber=JCD2290HES
http://www.repairclinic.com/PartDetail/Control-Board/1472681?modelNumber=JCD2290HES
heatman101
Nov 24, 2010 | Jenn-Air JCD2290HES Side by Side...
I have a side by side gallery, The freezer and fridge are working at the bottom, however, not at the top of the unit. Its like the cool and cold air is not getting circulated to the top of the unit. From...
check the damper door vent as it sounds as if it has frozen itself shut or possibly the cold control in the refrigerator has gone bad and can't control the door,the door is usually behind a diverter panel or a grille where the fan forces the cold air in from the freezer,the cold control is the component that you adjust to change refrige temp setting
Mar 28, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigrator will not get cold
replace the control board in rear of unit $80.25
Oct 18, 2009 | Whirlpool Refrigerators
MY FRIDGE IS NO LONGER GETTING COLD.
You created air pockets in the cooling unit when you flipped it over. Pull the fridge back out and gently lay it on its right side (as looking at it from the rear). Let it sit there for 6 to 8 hours. The gently turn it on its top, again sit for 6 to 8. Then turn it on it's left side, let it sit. Then back up right, let it sit. Reinstall the fridge and it should work fine.
Jul 09, 2009 | Dometic RGE400 Top Freezer Refrigerator
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
