Question about Senco FinishPro 35 FinishPro 15 SLS15 3 Tool Finish and Trim Combo Kit
How to load nails into the magazine
I cannot figure out how to load nails into my Senco Finish Pro 35. The instruction manual is poor.
  • 10,865 Answers
Hi. Here are pix that show u what to do. http://www.senco.com/pdf/manuals/us/brad_nailers_11_06.pdf
be sure u are using senco headless nails and be sure the gun is upside down and that you load the nail row head first so the points are pointing out. J.
Posted on Jul 12, 2010
I can't shoot nails on my senco finish pro 35
Make sure you have the right nails and enough air pressure
Nov 18, 2017 | Senco Tools & Hardware - Others
My Senco finish nail gun only shoots a nail every OTHER pull of the trigger. It's a model SFN30 and does this about 65% of the time. It's clean and has really had very little use.
Your driver is not returning fully.
Most often this is caused by:
1) A bent driver blade - pull the driver out and inspect it, make sure it is straight.
2) A broken seal o-ring on the bottom end of the cylinder (#66)
Senco SFN30 15 Ga Finish Nailer Parts
Feb 16, 2017 | Senco Air Tools & Compressors
Senco frame pro 601 turns nail upside down with nail head going in wood first
The nails can turn over if you have the wrong angle or gauge nails in the tool. Make sure you are using the proper nails for your gun because they are not all the same.
Feb 19, 2015 | Senco Tools & Hardware - Others
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
I have an older pro 18 serial number is 03c19425. It shoots with out pushing the safety in and not sinking nails. It leaves them about an 1/8 to 1/4 out. What do I do.
The Finish Pro 18 is a very good gun but I wouldn't spend more than $50 to fix it. You can get the newer FIP18mg for around $90 which includes a new warranty. If you really want to repair your gun:
Go to www.senco.com, click on the link 'Parts Charts/Specs/Manuals' at the top, scroll down to the Finish Pro 18 and open the parts guide. You are going to have to find out what parts of the safety element are broken or missing. As for the not driving nails all the way in, you have worn or broken o-rings inside the gun. The parts guide shows you need a Senco repair kit #YK0393. Senco no longer makes this kit but sometimes you can find them online at aftermarket retailers. Just Google or Bing 'Senco YK0393'. If you can't find one you can order all of the required parts from Senco but you have to order each one using part numbers from the parts guide.
Feb 16, 2011 | Senco Tools & Hardware - Others
I have a Senco pro 35 18 gauge finish nailer been working fine now I just get air when I pull the trigger
could be a jammed nail in the nose/magazine area or a driver problem. is the driver fully retracted or stuck partially down in the nose. UNPLUG the air before checking. If the driver is partially down I would think a jam and fully retracted you might have an issue with the piston/driver assembly.
Feb 11, 2011 | Senco Tools & Hardware - Others
With the finish pro 35 can you use any 15 gauge strip of nails,glued or plastic strip
i believe that gun takes 16 gauge nails, and yes, all 16 gauge nails are the same, as long as they are strait, not angled
Mar 21, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
How to unload nails from Senco FinishPro 35
when you pull the spring back like your going to load it .put your finger in the hole and push it .you'll see that the nails will be release.
Mar 28, 2009 | Senco Finishpro 15 Finish Nailer & Sls15...
Just bought a senco pro 600 framer nailer what angle nail to use
My 600 uses 35 degree clipped head and is printed on the side of the magazine.
Mar 14, 2009 | Tools & Hardware - Others
Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Jan 01, 2009 | Tools & Hardware - Others
Senco FinishPro 35 FinishPro 15 SLS15 3 Tool Finish and Trim Combo Kit Logo
612 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
Mike
ray gallant
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
