Question about Sharp CV-P10MX Air Conditioner
Quits running, then flashes all three lights on panel
Try draining the water tank.
Posted on Aug 22, 2010
    New Friend:
Thank you so much! It worked.
Posted on Jul 02, 2013
What is stopping my TV from coming on?
The fly back is not functioning correctly, sesk a dealer or a shop that can look it over.
May 25, 2016 | Samsung HL67A750 67 in. TV
Have a 2000 Dodge ram with v6 engine that will not start, what can be wrong
Security light on/flashing. Check for spark at the plugs and check fuel pressure. With security, Dodges will start and die, three times, then nothing.
Jul 22, 2015 | 2000 Dodge Ram 1500 Truck
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
All three lights on throttle are flashing, motor will not run.
Have you had it in freewheel mode? It sounds like its not quite clicked back in to drive mode.
Oct 18, 2013 | Currie Technologies Electric Scooter: EZIP...
Affinity Dryer has all LED lights blink and then it stops running
Hello everclavel - Try reprogramming the dryer by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the dryer could possibly be experiencing a communication error with the main control board, wiring failure, or faulty door lock assembly. Connect with a certified technician to move forward accurately to assist with the repairs.
Jan 29, 2013 | Frigidaire Electric Dryer
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    How to reset the oil change light?
    super easy. gm did 2 things. in the fuse panel drivers door. there is a reset button. this resets for oil change light and low tire pressure. with key on hit the button, one of these light will be flashing, keep hitting it til change oil light is flashing. once it is flashing hold reset button til car dings and light stops flashing. done. if you have no reset button then turn key on press gas pedal fully down three times within three seconds of eachother light will flash and go out. good luck. these procedures are also in your owners manual.
    Feb 22, 2011 | 2002 Pontiac Grand Am
    MY Sharp LC46D62U wont turn on
    Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
    Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
    All three lights are flashing on my HP Deskjet 6127. I tried unplugging it from the power source and then plugging it back in. When I try to turn it on all three lights flash and it won't turn off with out...
    Hi
    The HP Deskjet 6127 has four buttons and three lights on the front panel
    Flashing lights on the printer indicate the status of the printer
    When all the lights are flashing, the printer may need to be restarted
    try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
    2nd press the power button to turn off the printer and hold it down.
    Good luck
    Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
    1994 Maxima anti-theft
    If the light is flashing than the anti-theft is activated. Try locking and unlocking the car with the door lock button on the drivers side. lock and unlock a minimum of three times until the light quits flashing. If the car has loaded up (smells like fuel when cranking) then pull the fuel pump fuse and hold the throttle all the way down when cranking to clear the cylinders, then replace fuse and repeat the procedure with the lock switch if the light is still flashing. It should fire right uo if the light is no longer flashing and the fuse (15 amp) is put back in.
    Aug 05, 2008 | 1994 Nissan Maxima
    Sharp CV-P10MX Air Conditioner Logo
    370 people viewed this question
    Top Sharp Heating & Cooling Experts
    Oloyede Monsuru
    AJMAL KHAN
    Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
