Question about Dell Dimension C521 PC Desktop
Power button flashes and wont turn on
Unplugged in and know that i plugged in back in it wont turn on. the power button just flashes?
    Scholar:
  • 135 Answers
Hold the power button till it goes off. Then power it back up sounds like its stuck in power saving mode. let me know
Posted on Jul 12, 2010
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Computer wont turn on
Make sure the tower is getting power. There will be a green light on the back of the tower where the power cord goes. Make sure the cord is snug and that it is securely plugged in to your power source - I'm hoping it is a power surge strip and in which case, make sure the surge strip didn't get unplugged or turned off. If you have it plugged directly in to the wall then make sure that outlet has power by plugging something else in to it that you know works. After doing all of this, make check to see if there is a light on the back of your pc. If not, unplug the power from the back of the tower, wait 30 seconds at least, and then plug it back in. Hit the power button on the front just once, if it doesn't power up, press and hold the button in for a 2 seconds and release. If that doesn't work, your power supply may have gone bad. That happens from time to time. Good luck, hope this helps!
Jan 20, 2013 | Thermaltake Computers & Internet
Turned compaq off to clean it with air took off side panel put it back together now it wont turn on and there is a green light in the back flashing and making a ticking noise dont know what to do
power system off, unplug from power, while unplugged, press and hold power button for 10 seconds to discharge any residual power. Wait 3 minutes, plug system back in and try again, see is same issue occurs. IF system boots, great. If not then likely the power supply has failed.
Dec 26, 2010 | Computers & Internet
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
Have a canon mp 240 keeps flasing P and 3 and the alarm light and on button are also flashing......what the it wont scan it wont print does any one know what this means
When the Power and Alarm lamps flash alternately, and P and number (error code) are alternately displayed on the LED, an error requiring servicing might have occurred.
Turn off the machine, and unplug the power cord of the machine from the power supply. Plug the power cord of the machine back in, and then turn on the machine. If the problem is not resolved, contact your Canon service representative.
Nov 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Wont turn on i get a flashing lite in the power on button
A flashing power light usually indicates a hardware failure. Try unplugging the computer for 30 second then turn it back on and see if it starts. If you plug it back in and it starts flashing again it is a bad piece of hardware (probably motherboard but no way to know for sure without testing)
Jun 24, 2009 | Compaq Presario 5000 PC Desktop
It turns on with no picture then shuts off. Red light flashes in front by power button. Wont turn back on until i unplug and plug in
There are multiple fixes for solid red status or lamp light. I need to know which.
bigtvfixer@yayoo . com
Jun 03, 2009 | Toshiba 57H84 57" Rear Projection...
Turned off compaq presario desktop and now it wont turn back on. I used the start menu to shut down. Everytime I press the power button a light flashes over a symbol that looks like a lightbulb. Help
Try the following:
1. If connected to surge protector, make sure it's on. If it is, then...
2. Try plugging computer directly into wall and turn on...if no then...
3. Unplug and plug the power cord back in and then try to turn on...if nogo then...
4. If there's a switch on the back of your pc that has 120/240. Switch it back and forth back from 240 back to 120, turn on again...if no go then...
5. Unplug everything from the back of your pc except power cord, keyboard, mouse, and monitor. Try again. If it still doesn't turn on.. let me know. By chance, has any power outage occured or any change been done to pc since it was last turned on?
Dman
Jan 08, 2009 | HP Compaq Presario SR1123WM PC Desktop
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Dell Dimension C521 PC Desktop Logo
345 people viewed this question
Alun Cox
