Question about Acer Aspire 5520-5908 Notebook
In an aspire 5520G should the laptop boot without a battery inserted if plugged into power?
    Scholar:
  • 96 Answers
Yes it would turn on and boot. Take the battery out first. then plug in the AC adapter. turn the power on. You would be prompted that you are running AC power and no battery detected on most cases.
hope this helps.
Posted on Jul 12, 2010
Aspire 2225g works only without battery
You need to replace the battery. A lot of laptops will work from AC adapter when the battery is out but when the battery is installed they default to battery and the AC adapter defaults to charging. When the battery is bad you get the results you describe. If for some reason it did the same thing with a new battery then the power circuit would need to be replaced, but this is not typically the case. Almost every time I have fixed someones Laptop with the problem you describe, a new battery was the solution.
Mar 17, 2014 | Acer Aspire Computers & Internet
I have a portable computer ACER ASPIRE 5520G. When i power on the computer by pressing the power button the power button light on and off but the compter does not power on.
try remove power supply and battery and long press power button to 60 sec. then plug your power supply without battery then press power on!
Feb 04, 2013 | Acer Aspire 5520-5908 Notebook
Tpm not found or tpm problem on acer aspire 5520g
solution is try to re install the Windows Vista back and see whether the TPM will show missing. sometimes thats happening to most of the systems. when you try to put another windows thats did not came with the product, you will miss some functions such as drivers, battery not charging, internet not working, audio not working and many more. so put back windows vista and whether your problem still existing.
Sep 08, 2012 | Acer Aspire 5520-5908 Notebook
I have an acer 5520g, the screen remains black, have tried fn f4, takentn battery out held power button down, still nothing anyideas please?
if the computer seems to be booting you might have a bad lcd back light what you can do to check is hook up a external monitor to the unit,
let me know if you have questions
Oct 02, 2010 | Acer Aspire 5520-5156 Laptop
Can not restarted after putting it to sleep
pull the battery out, then back in and retry,
Look to see if you get a charging light when pluged in, if you dont then the power plug or power jack is bad and the battery cant charge
May 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
My aspire 5520g/5220 laptop just stopped coming on
first check your laptop charger if it ok than check motherboard power supply of laptop..there are must some problem on motherboard.
Apr 09, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hello! I have an Acer Aspire 5520G Laptop 2 years old. On the weekend it suddenly decided to stop working. When I push the on button it goes to power up, the light flashes green and then it clicks and...
Try to check the memory card reseat or clean it ( the edge connector with gel eraser), do this when battery is out and its AC power plug.
Did it undergoes some maintenance check in two years. Maybe you should, dirt, dust build up maybe the cause, and some contact is building a thin film of insulation commonly on copper coated connector.
Sometimes some add in device is out/faulty causing erratic behavior. Other thing is the hard drive and ODD devices. Reseat ODD and hard drive.
And oh, check your battery, one usual suspect of that.
Sep 30, 2009 | Acer Aspire 5520-5908 Notebook
Will not power up, no lights or sound
tried to remove battery and ac for a little while?
if that doesnt work, remove battery and ac-power.
remove the ram
put ac-power back and try to boot without ram
(do you get a beep/error?)
remove the ac again
insert the ram
insert battery
insert ac
try to boot up again.
if that doesnt work its probably a mainboard error and you need to take the computer to repair.
May 29, 2009 | Intel Everex LM7WE Notebook
Acer 1641 laptop keyboard doesnt work
we removed the battery and used only the AC. all works fine.
Nov 26, 2008 | Acer Aspire 1642WLMi Notebook
Acer Aspire 5520-5908 Notebook Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
