Question about HP Photosmart C6380 All-In-One InkJet Printer
Last page prints first
Our pritner prints from the last page first, so that the 1st page comes out last. Do you know how I can change that so that the first page comes out first and the last page comes out last?
  • 60 Answers
Usually if you go to the prineter preferences you can reverse the order of the pribnt. This will probably be ona std settings page rather than on the paper selection
Posted on Jul 12, 2010
Testimonial: "Thank you. Your solution was perfect. Our printer now prints the pages in the order we wanted. Also, I was surprised at such a quick response!"
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows)
a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
Dec 28, 2013 | HP LaserJet 5200 Printer
How do i get printer to print page 1 first instead of printing last page 1st
Hi, as you said your printer is printing the last page first and you want it print first page first, please follow the below steps:
Open any document that you want to print.
Click on File or window button from task bar.
Click on Print(a window will pop up)
Click on Properties.
under Page Order > select Front to back.
Click Ok and print.
Feb 25, 2010 | Computers & Internet
I would like to know how to stop getting the last page?
Usually this is because the file is just a tiny bit too long or they have a page break at the end...
AS A test, when you get the printer screen before telling it to print, select to print pages from this to that number and bump the last page down one number and see if it deletes that unneeded page...
I know the problem and it is annoying to waste a sheet.
Jan 23, 2010 | Canon PIXMA MP760 All-In-One InkJet...
HP officejet 9130 printer: pages keep printing
Yopu can change the rprinting order from the Print Dialogue box or Printer driver.
Look for the following to change page grouping when printed
and the followintg to change printing from first to last and last to first pages
Nov 13, 2009 | HP OfficeJet 9130 All-In-One Thermal...
In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried...
rint Preview my booklet looks... Solve In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried
Sep 11, 2009 | Microsoft Office Professional 2007 Full...
We are setting up new TallyGenicom LA800. However, printout has dot or period in between each characters printed. Hence, a single row info is printed on two rows. What seems to be the problem?
It would be strange for the printer to print dot between each printed character without this coming from the system.
As a check the first thing I would recomend doing would be to print a self test print on the printer, you can do this easiest by printing a menu print.
To print a menu print put the pritner OFFLINE
Press SETUP
Press the button under MENU
Press the button under PRINT.
The printer should print out its configuration page, if this has dots between each character then this defiantly means you have printer problems.
You can try defaulting the pritner back to factory settings, this is down by holding down the four buttons (1, 2, 3 & 4) under the LCD display whilst powerind the printer on.
If the menu prints OK, then there is some sort of other strange system or communication problem.
If the pritner is connected via serial, check the serial settings on the pritner also chack the pin configuration of the connector used to print to the printer.
Try printing from another system or application to identify what might be causing the problem for example an application or driver problem, perhaps try printing from a PC directly to the pritner to check the interface on the printer is OK.
Check the emulation setting on the pritner ensure this is correct.
Aug 02, 2009 | Epson Stylus Photo 2100 InkJet Printer
My printer is printing the pages too far up and over to the right
To aling the printer, try to  go to  tool  option in printers menu and press aling option. Also try to set all printer settings to default. If you are facing difficulty to print from all kinds of applications from your computer than issue can be a driver issue. So try to  add  a HP990C deskjet pritner and try to print using it. It should work.
Jan 22, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer Page Arrangement backward
Please access the driver properties > Advance Tab > printing defaults button > Click on Advance Tab > Layout option > select front to back
Also perform the following.
driver properties > General Tab > printing preference button > Click on Advance Tab > Layout option > select front to back
let me know if that fixes the issue
- Nikhil
Jul 02, 2008 | HP LaserJet 4250dtn Printer
Help
1st page prints perfect but the 2nd page comes out with very light and skipped printing.
Oct 22, 2007 | HP DeskJet 5550 InkJet Printer
HP Photosmart C6380 All-In-One InkJet Printer Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
