Question about Kenmore 13599 / 13594 / 13592 Built-in Dishwasher
Kenmore Dishwasher Model# 665.13592K600 stopped working. ''Pots and Pans'' button flashes green light. Other buttons not responding. Bad control board? Is there a reset option?
  • 478 Answers
Try resetting breaker if there is no off/on lightswitch type. If continues its the control board a really basic repair skills needed.
Posted on Jul 12, 2010
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
My kenmore dishwasher, model 15822, just stopped working. The quick rinse light is blinking. The only other buttons that work are the pots & pans light which blinks when pushed, and the cancel button...
These are known to develop sticky switch contact pads. They stick in the contacted position and stifle the panel. Sometimes heat can be applied with a hair dryer to release them and make the unit function again. This is more than likely a temporary fix. New panels are available for about $165 to $200.
Jul 16, 2009 | Kenmore Dishwashers
The Pots Pans button flashes and won't let me change it
Go to your circuit breaker panel and turn off the circuit that feeds you dishwasher. Leave it off for three minutes. This will reset the program and should solve your problem.
Apr 04, 2009 | Kenmore 15634 Built-in Dishwasher
Kenmore dish washer lights up but will not start wash cycle.
turn off your dishwasher then try it again ok
Feb 27, 2009 | Kenmore Dishwashers
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Dishwasher will not start..we've had it about 3 to 4 years
Some of these units have a thermal fuse in line with and mounted on the control card. This will need to be checked. Also check the door switches. Some models will aloow power to the control card but to nothing else.
Oct 12, 2007 | Kenmore 16872 Built-in Dishwasher
Kenmore 13599 / 13594 / 13592 Built-in Dishwasher Logo
748 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
