Question about Maytag MER6772 Gemini Electric Kitchen Range
On indicator lamp stays on even after all knobs have been turned off
    Genius:
  • 1,416 Answers
what this mean is an indication that there is a power bridge up from the wire connecting/supply power to the range ,(that is there is a wiring problem on the wire connection now)
what you are to do to fix up the problem first of all disconnect the range from the wall (main power supply)
Posted on Jul 12, 2010
  • Maytag Master
  • 3,361 Answers
One of your burner switches is defective.
it should be replaced,however,it is not dangerous.
Replace filters light stays on even after changing wicks. How do I turn it off?
You didn't specify what brand/model of humidifier your using, but you can still try a couple of things. (Try the most logical first).
Try turning the control knob to the "test/reset" position & wait until the humidifier "on" light blinks; indicating it is resetting the timer & the change filter lamp will turn off.
I believe that you will need to do this while the furnace is calling for heat, if it isn't, turn up the thermostat and try it.
Jan 05, 2016 | Humidifiers
Chevy trailblazer problems
its either a bad door switch,or could be the dome override switch by headlight switch,or your interior light switch is all the way up
May 01, 2014 | 2004 Chevrolet TrailBlazer
Element light stays on after all power control knobs are in off position?
Good Afternoon Cindy,
I see that you are having trouble with the element light staying on after all power control knobs have been put into the off position on your Frigidaire range, model# FEF366EC. The Element ON indicator lights will glow when one or more of the surface elements are turned ON. A quick glance at these indicator lights when cooking is finished is an easy check to be sure all control knobs are turned OFF. The Hot Surface indicator light will continue to glow AFTER the control knob is turned to the OFF position and will glow until the heating surface area has cooled sufficiently. I suggest resetting your appliance by shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "clock" button, and then you will press and hold down either the up or down arrows until the correct time appears. Try turning the burner on that the indicator light stays on the most. When you turn it off if you are still having trouble with the element light staying on, I suggest contacting a local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire FEF366EC 30" Freestanding...
My voicemail indicator message lamp stays on.
What voicemail do you have?
Vm Pro or embedded?
If voicemail pro, you will need to navigate to the folder where your messages are stored on the pc, delete them, then stop/restart the vmpro services. If you dont know what I am talking about, I would call someone in that is a knowledgeable tech....
Oct 21, 2009 | Avaya 5400 Series 5410 Phone
Replaced lamp, still does not turn on.
LAMP #BP96-00826A
IF THE TV STAYS ON FOR 30 SECONDS IT MAY BE AN INDICATOR OF A POSSIBLE POSITIONING ISSUE WITH THE LAMP DOOR SWITCH (LITTLE BLUE SWITCH AT LOWER LEFT OF CABINET WHEN LAMP DOOR IS REMOVED.) THIS SWITCH IS SUPPOSE TO BE IN THE DOWN POSITION ONCE THE LAMP DOOR IS SECURED AND HAS CAUSED CONFUSION BEFORE.
HOPE THIS HELPS
Jul 06, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Front turn indicator stays on
bad lamp or it is loose lamp replace lamp check connections
Sep 09, 2008 | 1999 Chevrolet Blazer
Lamp indicator blinks red
There is a problem with the lamp or around it? When it turns Orange, the lamp is at or near the end of it's life & needs replacing. What does the temperature indicator show? Orange, Red or Red Flashing? If not, then there is probably accumulated dust around lamp area
Dec 24, 2007 | Zenith E44W46LCD 44" Rear Projection...
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
149 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
