Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
No power I can not get the tv to come on. I have unplugged it and plugged it back up, plugged it into a new socket and it still will not come on.
  • 11,361 Answers
Will not come on
First make sure there is power in the socket you are plugging the unit into. If that's OK and the unit has been plugged in then 1) Disconnect the TV from the power by unplugging it from the wall socket. 2) Wait 20 minutes and then plug it back in. 3) Turn it on and see what happens.
I've seen a number of LCD TVs some back to life if these three steps are taken. It allows the TV to reboot itself after all internal capacitors are discharged.
Mar 24, 2015 | Apex Digital Apex 40" Class 1080p 60Hz LCD...
Plasma TV-power light does not come on
have you tried a completely different wall socket altogther/
Mar 03, 2008 | Samsung HP-S5053 Television
Will not come out of standby
Try unplugging the power cord from the wall socket for a couple of minutes, then plug it back in and see if the TV will turn on.
Jul 30, 2014 | Sanyo 42 in. LCD TV
My tv has no power at all
U check the power source like the power socket outlet?U tries tv unplug,replug the tv back like about hour later see if the tv resetting itself back to the factory setting and work again.Same result after this ur tv still have no power at all than the tv have a dead power supply board.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Aug 31, 2011 | Astar LTV-32HBG 32 in. LCD Television
Unplugged tv and when plugged back in doesn't come on
Hello
If you have unpluged the TV from wall socket and it doesn't come On when you plug in back, either its power supply system or its stored memory has the trouble. Look whether the power indicator light coms on. Ensure that the main power ON/OFF switch at the front panel of the TV is ON. If the front panel power switch, control switch of your wall socket, and all the other electrical connections are OK, and still the TV doesn't come ON, surely the power inverter baord has the trouble and must be either repaired or replaced. if the power indicator light comes on, and your TV doesn't come ON by remote POWER ON button, the settigs that were stored has vanished, and resetting it to its original setting is necessary. Follow its manual for 'initial setup" and so all the recomended setting there. OK.
Apr 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
The tv came on then the screen went black but there was still sound for a sec. Now the green light keeps blinking and the tv won't turn
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Dec 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Power wnet off and tv will not go back on
might sound daft but plug a lamp into the socket ware the tv was plugged in if that works check the fuse in the tv plug if all ok and still nothing unplug tv for a few hours and make sure power button is out (off) then plug back in then try power button and then try to start tv by the channel buttons on the tv instead of remote
Jun 05, 2010 | Insignia IS-LCDTV32 32 in. Television
The power cord hard to unplug from back of tv for wall mounting job
step-1.
first switch off your tv unit and if possible switch off yuor main switch also
step-2.and pull out the plug bu holding the hand inth end of plug not in wire .
still you have the problem
follow step-1. and using wd 40 liqiud (available all electronic shops ) apply between wall socket and juntion of plug
and wait for five minites
then try step-2.
finaly remove wall socket and try it now and remove the plug.
Oct 26, 2008 | Electronics - Others
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
152 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
