Question about Refrigerators
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram. Almost all refrigerators have a hidden paper wiring diagram. It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan. While you're in there, it's a good practice to clean the coils.
Posted on Oct 23, 2007
SOURCE: GE Profile SxS Refrigerator wont defrost after new heaters installed
The answer to your last question would be yes. You can test for voltage at the harness where you plugged in the new assembly. With the refrigerator defrost timer in the defrost mode do your voltage test. The thermo stat for the defrost does not close until the temperature drops to about 16°F. If you have and Ohm meter you can test for continuity through the heater assembly by testing heater end to end and bypassing the thermo disk. If you have voltage at the first point test where you connected the harness your timer is O.K.. If there is no voltage with timer in the defrost position it could be bad.
Posted on Apr 30, 2008
SOURCE: Replacing a relay switch/kit on a maytag refrigerator MSD2432GR
Wow! I am confused also. It sounds like it is more complicated than the ones I use. Can you send me an image of the relay and the terminals on the compressor?
I can tell you that the live wire ( wire with electricity) is the one that goes on the common terminal, that is the one that it at the top of the trangle formation, unless the formation is upside down then it goes on the bottom. Then the other neutral wire goes on the run terminal which is usually on the right if the triangle formation is right side up. Usually the neutral wire is white. So
try putting the white wire on terminal 3 and the orange on the top (or bottom) terminal. If there are any wires left over that you think need to be connected I would need to see an image.
Posted on Dec 05, 2008
SOURCE: kenmore fridge start relay wiring
there is no need to shroten the lengths of the wires, u can directly connect it
Posted on Mar 10, 2009
SOURCE: wiring diagram for thermo king street boss
need the model number for this one
Posted on May 10, 2009
May 05, 2016 | GMC 2000 W4500 With 16 Thermoking Reefer
Feb 12, 2016 | Cars & Trucks
Mar 20, 2015 | Refrigerators
Mar 05, 2013 | 2004 Suzuki Verona
Dec 03, 2012 | Cars & Trucks
Dec 28, 2009 | Sprint BlackBerry 8703e Phone
May 10, 2009 | Refrigerators
Apr 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
138 people viewed this question
