Question about HP Photosmart C6380 All-In-One InkJet Printer
I have a HP Photosmart C6380 printer locks up & gives error
I have a HP Photosmart C6380 printer when I turn it on, the ink cartilages move all the to the left and I get clear paper jam then press OK. Couldn't find any paper any where in the printer then I hit Ok and I get an error saying "Improper shutdown" to turn off the printer with the on switch and not to pull the plug. then The ink holder will slam into the left of the printer and I get "Clear paper Jam then Press OK
  • Duane Wong
    Duane Wong Jul 12, 2010
    I've experienced a similar problem on HP printers before. Is this printer under warranty?
  • 60 Answers
It is likely that you have had a jam which damaged the sensor when you removed it (itr if you print lables gunked it up). If it is likely to be gunked up you could strip and clean but to be honest it is probably not worth the time. If this has iccurred following a jam - unless you have another identical machine for spares bin it and get a new one as the parts are difficult to come by and labour will be steep unless you can do it yourself of course
Posted on Jul 12, 2010
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Paperjam in a hp photosmart c6380 all in one , how do I open to clear out paperjam ?
I could provide you with written instructions to clear paper jam, however i thought it would be good to provide you with a link to solve it for better understanding.
Click on the link below and it will give you step by step instructions to clear a paper jam with video demonstration.
Clear Paper Jam
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | HP Photosmart C6380 All-In-One InkJet...
Mt HP Photosmart C6380 keeps wadding up the paper and gets jammed. It then says out of paper and when I clear it and press OK, it crinkles the paper to death. Please tell me how to fix this. There is...
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | HP Photosmart C6380 All-In-One InkJet...
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
Getting black streaks across documents and pictures
Usual cause is defective bllack cartridge or it needs to be removed and excess ink cleaned from the face of it.
SOMETIMES using too heavy of paper can bend up an touch the bottom of the cartridges as tehy move across to page.
Also a paper jam can brush the cartridge and after that the ink is smeared on the cratridge face and will mark the paper as it moves across.
Using BAD refilled cartridges is a common problem.
Nov 08, 2009 | HP Photosmart C6380 All-In-One InkJet...
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart C6380 All-In-One InkJet Printer Logo
277 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
