Question about Brother PT-1750 Thermal Label Printer
Power shuts off P touch 1750 label maker
Power shuts off immediately after I turn the machine on. I used the machine earlier today, the tape ran out while I was printing labels. I repalced the tape cartridge with a new one. Now the machine won't function at all. I use an ac adapter. I checked the connections. I even tried 6 fresh AA batteries. With no batteries or ac adapter connected, it still lights up P-Touch then shuts down again.
  • Anonymous May 13, 2008
    brother p-touch will not power on
  • Anonymous Dec 05, 2008
    same deal. it might turn on for a second to say "P Touch" but then immediately off.
  • 247 Answers
SOURCE: labeling system trouble-shooting
I thought the PT65 took a thermal tape that didn't have an ink ribbon. Compare the part number on the tape cassette with the list of compatible types listed in the labeller's instruction manual. Believe the only compatible cartridges are: M-Knnn/B, where NNN is one of 221, 222, 223, 231, 232, 233, 521, 531, 621 or 631, or M-K221S/B or M-K231S/B A.
Posted on Feb 11, 2007
  • 624 Answers
This is a duplicate post, click on the following like for the original:
Posted on Mar 04, 2007
  • 120 Answers
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here:
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
Posted on Jul 11, 2008
SOURCE: Printing labels
You have to feed the labels through the manual feeder.
Posted on Oct 30, 2008
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Posted on Dec 29, 2008
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more:
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
My ptouch 1750 gives me an error message that says "no tape!" but i have tape installed. help!
Hi, Make sure that the cartridge is installed and that there is no slack with the ribbon. You can turn the tape by advancing the tape in the center of the cartridge wheel, IN THE DIRECTION of the arrow on the cartridge. You can advance the tape by pressing 2 buttons: CODE and Space
Also if you installed a new cartridge, make sure that you removed the safety cover.
Hope this helps.
The owners manual can be found at this address:
Have a good day.
Mac =)
Apr 22, 2013 | Brother P-Touch 1750 Label Maker
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
My ps 1100 label maker prints only on black side of tape
This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
Just replace the tape cartridge
Apr 01, 2010 | Brother P-Touch (PT1100SBVP) Label...
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
Brother P-Touch 85 only prints one vertical line,then shuts off
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Brother P-Touch 85 Thermal Label Printer
Labels are not printing correctly
Brother P-Touch tape label maker doesn't print right.
I believe it's a faulty tape. I put in a new tape, reset the machine and it's now printing fine. It wasn't the reseting - I tried that before.
Mar 11, 2008 | Brother P-Touch 2200 Thermal Printer
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
Brother P-touch labeling system PT-1750
You dont. This machine was designed to waste your money and raise Brothers profits.
Oct 04, 2007 | Brother PT-1750 Thermal Label Printer
Brother PT-1750 Thermal Label Printer Logo
149 people viewed this question
James Cagle
James Cagle
Jim Keysor
