Question about GallienKrueger Gallien Krueger 800rb
My 800-rb won't power up.Nothing lights up...checked fuse and its ok.
  • GallienKrueger Master
  • 5,603 Answers
Starting point is to open the unit and verify first that the +/- 60 volt power supplies and the +/- 85 volt supplies are producing.
Next check the +/- 15 volt regulators.
You will likely find one or more of these supplies are defective.
Cause could be blown parts or cracks in circuitboard or bad wiring.
Posted on Jul 13, 2010
I have been playing my clavinova as usual, then suddenly the power went off. We have no power cut and all plugs are okay. Help!
Do you have a red indicator light or any type of illuminated display?
check fuses\n plug, if this is ok there are a couple of internal fuses.
obvioysly make sure you disconnect the mains cable before opening the keyboard, if these are ok then unless you have technical knowledge I would seek the advice of a Yamaha repair specialist.
Jun 23, 2017 | The Music
Yamaha me-50 no lights no sound what to check?
Check the output of the power supply itself.
Jul 13, 2014 | Yamaha Music
Peavey xr 8600 about 6 yrs old used weekly heard a loud pop them a low emiting hum no sound comes thru .... is it time for a tech ? or dose it sound like an easy fix like fuse or something power on board...
Check the caps in the PSU, these give out over time although not normally when used regularly. You may be lucky and be able to see one or more with bulging tops. If you can replace them and all MAY be OK. Whilst in there check for any visible signs of anything burnt or blown. If it looks too bad or there is nothing obvious it's a trip to the repair shop for certain.
Oct 05, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey jsx 120w combo amplifier
Check for power supply fuse, if this is ok then check for all tubes glowing as it should be, let me know your results.
Jan 16, 2013 | Peavey Music
Fender G-DEC junior won;t power up the lights don;t come on it has a thermal cutout on the 12VAC transformer it was open circuit i tried bypassing it with soldered jumper still does not power...
Try changing out the Pico fuse. Only 50cents from online West Florida Components. Buy a few. Mine went out twice. It is Item # F021. It is a .5amp (500 mA)fuse-green and looks like a resistor. Location on the circuit board is near the transformer and on back edge or board behind the 2 brown wires connecting to the board and to the side of the 4 diodes there. I left the bad fuse in place and soldered the new fuse to it's legs-a lot easier and does not damage the PCB.
Oct 03, 2011 | Fender G-DEC Junior Modeling Guitar...
I purchased a Passport 500 less than one year ago, used it maybe 10 times and recently turned it on to use and it would not power up. No lights nothing. Checked the fuse ok. Tried a new fuse nothing. ...
Check that the power cord is seated completely. These are hard to work on and if there is a failure in it, it is unlikely you will get it restored in time. I would suggest renting a system until you get it repaired. You need rent only a powered mixer with suitable cables as your speakers should be fine. The way the Fender Passport is packaged makes them difficult to work on.
Jan 11, 2011 | Fender Passport Deluxe 500watt Sound...
Power light flashing but getting nothing through the tower
If the fuse went, there probably is a failure. To avoid further damage, if you replace the fuse, put a 150 Watt lamp in series with the hot power wire. Make an adapter to do this safely.
The lamp will light instead of the fuse blowing and hitting the amp with a high current surge that could do more damage. If the lamp goes out, it is probably safe to operate.
I would recommend carrying a spare amp with you... These Passport systems are HARD to work on due to the way they are assembled.
Nov 14, 2009 | Fender Passport Deluxe 500watt Sound...
GallienKrueger Gallien Krueger 800rb Logo
243 people viewed this question
Top GallienKrueger Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a GallienKrueger Music Expert? Answer questions, earn points and help others
