Question about Dryers
Replaced ignitor and thermal fuse but the dryer still won't heat up.whirlpool #LGR5848E
    Genius:
  • 1,416 Answers
Did you consider your wiring connection and also the element (heat provider it always in silver color ) if it well connected
please look into that
thank you.
Posted on Jul 12, 2010
    President:
  • 1,099 Answers
There comes a time in every person's life when the unexpected happens. You throw a load of wet clothes in the dryer, twenty minutes later the dryer buzzes its finale, and you return to find the clothes just as wet as they were when you left them. Oh, the humanity!
But wait - you're a tried and true Do-it-yourselfer, and I'm going to help you fix your dryer. Start by reading our article describing how a dryer works before tackling a problem head on. For many of these problems, finding the solution may require the use of a Volt-Ohm (VOM) reader. They can be picked up at most hardware stores. As always, try to rule out the problems that are easiest to repair first.
Access to most or all of these parts will require removing various parts of the dryer. Be sure to keep track of which screws go where, so when it's time to button everything up, you know what to do. As always, unplug the dryer, or turn the power OFF to it before we begin!
Problem: The drum spins, but there is no heat.
Solution: This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
  • Fuse could be bad -- Check the fuse for a break inside. If it’s bad, replace it with an identical fuse.
  • Temperature switch could be bad -- Use VOM to check the switch. Set VOM to RX1, remove leads and touch the probes to the switch's terminals. The reading should be zero or infinity. Turn the switch, and the reading should change from zero to infinity or infinity to zero. If not, the switch is bad.
  • Thermostat could be bad -- Set the VOM to RX1, take a lead off one of the two outside terminals and press the probes to the two outside terminals. There should be a reading of zero. If not, it's bad.
  • Heating coils may be bad -- Set the VOM to RX1 and remove the leads from the coil. Press the probes to the terminals. If the reading is zero, the coil is bad.
  • Timer could be bad -- Disconnect the leads from the motor. Set the VOM to RX100. Clip the probes onto the leads. If the reading is infinity, the timer motor is bad.
good luck
A whirlpool gas dryer will not heat up
If your dryer is not getting any heat, you need to make sure there is nothing blocking the vent. IE: LINT. Air flow is key to efficient drying. Make sure the dryer settings are appropriate for the clothes you want to dry. The timer selection, fabric selection, and the temperature selection all play important roles in proper dryer operation.
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
• Heating element (For Electric Models)
• Burner operation (For Gas Models)
• Ignitor (For Gas Models)
• Thermal fuse
I WOULD START WITH:
To protect from over-heating, many dryers use what's commonly called a thermal fuse. If the thermal fuse gets too hot, it will blow, and completely shut down your dryer until it is replaced. This fuse is often mounted within the exhaust duct in the back panel. It's about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced. When replacing this fuse, check the dryer vents to make sure there is no lint buildup which can cause the heat to stay trapped and blow the fuse again.
Visually inspect your heating element for any broken or burned areas.Check the coil for continuity with a Volt Ohm Meter. If there's no continuity, it means that the element is bad and you need to replace it.
If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
Sep 28, 2013 | Home
LGR5636PQ0 Whirlpool Dryer has no heat
Possibly there's a problem on the coils inside that why it can't suppy the heat to the surface. Even the thermal fuse is ok but the coils supplying never responding to give such heat.
Feb 10, 2008 | Maytag Neptune MDG5500AW Gas Dryer
I have a Whirlpool gas dryer, it won't heat up. I replaced the ignitor, but it still doesn't heat. The ignitor doesn't glow either. HELP
Replace the thermal fuse . The little 1 " long , narrow white part , with 2 wires going to it . Without the model number , I cannot tell you where its located .
Jan 28, 2010 | Whirlpool Dryers
I have a whirlpool LP Dryer model #LGR5848E that won't start.
can you turn the drum by hand.
if not i would be concerned that you have a sock or something stuck in the blower sqiral cage.
if you can turn it by hand and it sspins freely, then you may have several issues, broken belt, is where id start,
the fact that you can hear a hum say the motor is trying
Oct 05, 2009 | Whirlpool Dryers
Whirlpool gas dryer LG6151XSWO...won't heat. I
THE MOST COMMUN THINS IS THE THERMAL FUSE!!! CHECK IT AND REPLACE IT IF NECESSARY!!
Oct 05, 2009 | Dryers
Whirlpool lg9521xt gas dryer- no heat or flame. I replaced thermal fuse and coil kit, but didn't solve problem. What's next ? The igniter ?
Remove the bottom panel and start dryer . If you see the red glow , then ignitor is ok . Disconnect the plug (2 or 3 wires ) going to the burner and check for 120 volts . If no red glow , replace the ignitor pt # 279311 . If not 120 volts , then , normally , thermal fuse is bad (white piece with 2 small terminals on blower box ) is bad .
Sep 07, 2009 | Whirlpool Dryers
No heat Whirlpool dryer
when you turn on the dryer does the ignitor glow if it does replace the coils if not check the thermal fuse
Dec 19, 2008 | Dryers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Gas dryer not heating up
Flash, did you check the thermal fuse in the back? On a gas dryer the drum will still turn if it's blown. check out the picture and post back.
Mar 29, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
127 people viewed this question
Top Dryers Experts
