Question about Sylvania 6842THG 42 in. Plasma HDTV
I'VE GOT A SYLVANIA 42 INCH PLASMA TV THAT SHUTS OFF
I'VE GOT A SYLVANIA 42 INCH PLASMA TV THAT SHUTS DOWN AFTER ABOUT A HALF HOUR AFTER YOU TURN IT ON , IF YOU PUT IT BACK ON RIGHT AWAY IT WILL TURN BACK OFF RIGHT AWAY. IF I WAIT ABOUT 20 MINUTES ,IT WILL RUN FOR ABOUT ANOTHER 30 MINUTES. TIA PHIL
    Brigadier General:
  • 8,619 Answers
Hi Tia,
Thanks for using FixYa. Hope you know that a plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems which seems to be the case with your unit. To start with unplug the unit and take the back off then check the power supply board for any bulged/swollen components. If you leave it unplugged for 20minutes the capacitors cools down and then the unit starts working after sometime, which states that its most likely either one or more capacitors on the power supply unit that are bad and should be replaced. All this is only recommended if you have electrical expertise and/or know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
42" sylvania 6842thg plasma displays digital television and then shuts off after about 1 minute.
Evening It is not energy saving that is bothering you,is it? Try SET-UP and see if you can change it there. Good luck Kolbrun
Aug 24, 2012 | Sylvania 6842THG 42 in. Plasma HDTV
Hitachi 42 inch plasma tv shuts off by it self
This is not really a solution, but read on... I had these symptoms in my 42 inch Hitachi plasma also.When I took it in to get it looked at , I was told that dust was accumulating on and around the cooling fans.He gave it a quick cleaning ( vacuuming I assume) and it worked for a while then started malfunctioning again. Now I'm trying to decide whether to just pitch it or keep cleaning it myself.Hope this helps.
May 31, 2010 | Hitachi 42HDS69 42 in. Plasma Television
When i turn my 42 inch plasma sylvania on, it makes a sharp high pitched squeal, then shuts off. it does this repeatedly, whats the problem, and how do i fix it?
You have a short on one of the drive boards making the power supply squeal. You will have to unplug each board until the squeal is no longer there. Which ever board it is will have to be replaced. Thanks for using fixya.
Nov 26, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Seems like a fuse blew on my sylvania 42'' plasma bought in 04?
it isnt a fuse, if your fuse was blown, it wouldnt even turn on, even for a second, it is your Y-SUS board, you can order one through there website, i think
Jan 10, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Vizio sp42a
your tv is having a problem of more than one component .to get rid of the problem u should rectify your vif horizontal and vertical sections
Sep 24, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
42 inch plasma
TURN OFF THE MAINS AND THEN SWITCH IT BACK ON
Jun 06, 2007 | Samsung HP-R4262 42 in. Plasma Television
Sylvania 6842THG 42 in. Plasma HDTV Logo
152 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
