Unfortunately, the picture error message means that the image been modified such that the camera can't read it. It is possible that the camera thinks the picture was taken by another camera. Since the picture is still good when you check it with the computer, it hasn't been damaged. Archive the picture and make sure to back it up after it goes on the computer. (If the computer couldn't view it, then you'd need some sort of file recovery software and might not get the entire image back.)
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
First things first - need to make sure that the card is making proper electrical contact with the camera. Have a look at the contacts at the edge of the card and make sure they are spotlessly clean - even a fingerprint may cause problems.
Also, make sure the contacts in the camera have nothing causing a contact problem, and see if this resolves the issue.
When I transferred those particular pictures to my laptop for some reason they were partially deleted from the camera which gave the 'picture error' message. Deleting that picture completely got rid of the message.
try to examine the card on a computer (e.g. with a card reader). are there any pictures on the card? if not, try formatting the card (see olympus manual for a how-to).
