Question about Westinghouse SK-19H210S Television
How to use a HD antana and program HD channels
Can't get the hd channels to program in
The HD channels will require using a HDMI or other suitable connection regular cable input will not allow HD channels
Feb 10, 2013 | Zenith R57W46 57" Rear Projection...
Cannot tune channels eg channel 9 10 7 only gets sbs abc nu-tec mod NUE 1958 18.5 " lcd
i had same prob untill i pluged it into a wall antana went auto setup australia DTV only and i got 7, 73 ,70, 71 , 90, 99,9,10,1,11, when pluged into a portable tv antana i lost 7, 73 ,70, 71 so that how i fixed my problem
Jan 06, 2011 | Televison & Video
I have the antenna plugged in to the tv, but I am not receiving any signal. I get a couple of channels, but none of the main ones.
Try buy a Digital antana design better signal stronger and longer ranges.Rescan again,u will get all the free DTV channels air broadcasting.
Dec 31, 2010 | Protron PLTV-37 37 in. LCD Television
How do i set the 2632 from cable to uhf/vhf antanna
Have a good antana like a roof or a HD antana plug into the ANT tv hole.Tv remote push the tv menu.Goto SETUP go down to CH.push and pick AIR not cable.Push for scan for free DTV tv channels.When finish scan u will have all the free DTV channels,depend how good is ur tv antana receptions is.
Nov 26, 2010 | Polaroid FLM-2632 Television
My jvc lcd does not work with my local air tv, i get weak signals
Ur tv is getting a free air DTV right?Not Cable tv,Satalite or Telicom compannies services?Yes,than.Get a better antana like a roof antana or Digital inside antana to get better stronger and longer ranges to recieve the signal.Go to ur tv Menu.Goto setup Ch. Pick AIR rescan all the free DTV signal again,u should get all channel and a strong signal.
Jul 29, 2010 | JVC LT-32E478 TV
My 47" LG has an internal HD reciever but it isn't picking up any HD channels.
Is it connected to an antenna? Did you do a channel scan for digital channels? See www.dtvanswers.com or http://dtv.gov/iguide.htm for more information.
Sep 03, 2009 | LG 47LC7DF 47 in. LCD HDTV
Hitachi 53FDX20B -- HD tuner?
hi, hd ready means the tv is capable of re-producing the hd picture from a cable or satellite co. call your local cable/sat people they can advise you which channels are which in your area, video-tek
Jun 06, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Onkyo 605 loss of audio on HD channels only
on your directv box, go to menu, setup, setup again, then audio, then dolby digital on the right and turn it on. assuming you have an optical audio cable from your sat box to your onkyo.
Apr 26, 2009 | Onkyo TX-SR605 Receiver
I have a Sony Flat Panel TV and I have a Comcast Cable. I am not paying Comcast for HD. Can I get HD on my HD TV without paying Comcast an additional fee?
you can get some hd channels without a cable box.
run the auto channel programming which may take 20 minutes. you will probably find the hd channels around 110. you will need to make a list of your favorites as the channels are numbered 110.1 110.2 110.3.
Jan 15, 2009 | Televison & Video
Favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
