Question about Cub Cadet Garden
Lt1045 keeps blowing the 20 amp fuse - Cub Cadet Garden
5 Suggested Answers
  • 138 Answers
SOURCE: Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Posted on Sep 07, 2009
dcurryn601
  • 60 Answers
SOURCE: My LT1045 blows the 20
you have to start with the switch and see if its faulty
see if you can replace it temp with a toggle switch
and check the wiring back to the pto as well it mite be grounding out
If not any of these then its in the pto its self
Posted on Jul 23, 2011
kel1guy2002
  • 3740 Answers
SOURCE: CUB CADET MOWER KEEPS BLOWING
Hi and welcome to FixYa, I am Kelly
The service manual is here:
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-02100.pdf
The wiring diagram is on page 84 of the manual.
Disconnect the positive and negative terminals from the battery and make sure they do not contact the chassis to form a ground. Read for a short with the key in run and lights OFF from the positive battery terminal to chassis ground. If you ar noting a short at this time you are literally going to have to chase wires. I would start by disconnecting the red wire from the PTO switch followed bythe red wire on the PTO relay. If the short goes away I suspect a problem with the wires at the PTO clutch as this is were many wiring problem manifest due to foreign objects thrown by the belt hit the wires on the clutch. After that I disconnect the engine connector and check again. Lastly I would disconnect the dash monitor connector and test again. If you still have the problem after disconnecting the engine harness and dash monitor there is a wire chaffing some where against the chassis. You can find it... it just takes a lot of time.
On another note...
You should probably make sure the ignition switch is not causing your problem.
Key switch testing connector removed
Off = M+G+A1 (continuity) Also read each one to the case of the switch
Run W/lights = B+A1+A2 and L (continuity) Read B + A2 to to the case of the switch.
RUN = B+A1 (continuity)
Start = B+S+A1 Read S to the case of the switch. (continuity)
Don't forget to remove the large (+) wire off of the start solenoid when troubleshooting or you will read the starter winding giving you a false ground.
Troubleshooting will end up being isloation of one leg of each wire at a time. I usually make a straight line sketch of wire temination points by wire color and connection on scratch paper for each wire I test and draw a single angle line across it after I have tested it.
If you determine that the problem is in the engine alternator, I will need your engine model number so I can get the service manual for that also.
A word to the wise.... if you disconnect a wire... write down color and where it was disconnected from on scratch paper. and line it out after you re-connect it. (experience)
Thanks for choosing FixYa,
Kelly
  • 6468 Answers
SOURCE: Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Posted on Apr 24, 2012
Will it hurt to replace the 20 amp fuse in my cigarette liter to a 25 amp it keeps blowing fuses
I am wondering if the fuse blows instantly or whether it lasts a while?
Fuse ratings for cars are usually mean or average values so a 20 amp fuse needs roughly 40 amps to cause it to instantly fail. I have not heard of a cigarette lighter needing that much current so I guess there is a fault that should be located and cured before you have a fire.
Maybe it is the element that is faulty...
I think fitting a 25 amp fuse would be slightly foolish...
May 12, 2017 | Cars & Trucks
Why does the ATC fuse keep blowing
Fuses only blow when the current is above the limit. Tripping a 20 amp fuse is a serous current, probably caused by a shortage. Check if an animal has eaten on your cables, or perhaps a cable lost its isolation and is now connected to the plating. Use a ohm meter and try to follow the cable from the fuse to in the car, till toy see something.
Jun 30, 2014 | American Terminal ATC-20-50 20 Amp ATC...
Apr 23, 2012 | Husqvarna Garden
My LT1045 blows the 20 amp fuse when the Electronic PTO is engaged.
Jul 17, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
2009 e250 keeps blowing 10 amp parking fuse then
if it keeps blowing the fuse you have a short in the wiring
Sep 11, 2009 | 2009 Ford Econoline Cargo
Fuel system blows 20 amp fuse
if its blowing the fuse, it might be a a bad relay that is drawing two many amps to keep it running. replace it
Jun 03, 2009 | 1993 Buick LeSabre
Keeps blowing fuses!!!
HI ..PUT AN AMP METER IN LINE TO SEE WHAT THE AMP IS DRAWING..WHEN IT IS CRANKED UP ..IS 20 AMP WHAT IT CALL FOR ON THE AMP IF SO I WOULD NOT GO ANY HIGHER.....BUT IF YOU HAD JUST USED 20 AS A STARTING POINT FOR AN AMP-AGE...SOMETIMES IT IS BETTER THAT THE FUSES BLOW ONCE IN AWHILE THAN THE AMP...ALSO CHECK FOR A LOOSE GROUND.....GOOD LUCK
Jan 29, 2009 | Planet Audio VX2002 Car Audio Amplifier
20 Amp FP/ASD Fuse #21 keeps blowing.
hmm. lt look like there are poor joints in your wiring specially the groung wire. check the diagram of your auto. check the unit diagram for which the fuse blows. usually the fuse blow when there is a short circuit. if you look around you will find it.
good luck
ehsan.
Jan 20, 2009 | 2002 Dodge Neon
Garden Logo
539 people viewed this question
Top Cub Cadet Garden Experts
DarkfireVA
Level 1 Expert
dannydoesita
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
