Question about Ovens
The warming light comes on and dings like oven is warming up but oven is off, then I get an F2 on the digital display and it kept dinging, now my oven will not come on or warm up, or my broiler
  • 677 Answers
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
Posted on Jul 12, 2010
How do i stop the buzzer on my neff oven. No timer is set but still dings.
Sometimes it is necessary to wiggle the time setting knob back and forth to get the buzzer to stop.
Jul 04, 2016 | Neff Ovens
How do I get the oven to stop ignition clicking
is this a wall oven? if yes and it is not a convection oven, then the clicking noise is probably the exhaust fan that makes sure the rear of the cabinet cavity that the oven is installed in does not get too hot. the fan blade is dinging on its housing most likely, pretty common. not a big issue, but a hard issue to fix.
Jul 19, 2015 | Ovens
My top oven is displaying some kind of error message. First it was F3, now it is F2. a loud ding noise comes with it. Help!!!
I get this, and F7 sometimes, especially after self-cleaning. Was told by a repairman to turn off the power, the breaker in electrical box and leave off. I usually leave off for anywhere from 5 hours to the next morning and then flip the breaker back on. Then it is fine. Happened to me 4 days before Thanksgiving too!
Nov 23, 2010 | DCS (WOTD-227) Double Oven
Can't turn off ring on oven timer. Ding ding driving us mad
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Nov 01, 2010 | Fisher and Paykel Ovens
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Timer keeps dinging and won't stop
it stopped really don't know what I did but it stop
Feb 12, 2008 | Neff B1428 Nostalgic Single circotherm...
Alarm continusly dings and display is blank.
Spencer...I hope you did this with the power off! First, disconnect all connections and reconnect them. You may have forced a connector. Likely the board is blown...the display and microprocessor are closely connected.
Jan 08, 2007 | Jenn-Air JJW8530C Expressions Collection...
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
F7 alarm
F7 stands for a faulty touch pad, faulty clock or both. Usually it's the touch pad. Most manufacturers recommend replacing both of the components. First, because they make more money that way, and second, it's the easiest (although more expensive) way to fix this problem. If you'd rather try and save some $$$, you can perform the following test and hopefully identify which of the two components needs to be replaced. The test... Disconnect the power to the oven before performing any repairs. Something triggers the clock to display F7 error code. You can unplug the touch pad from the clock and see if F7 comes back on. If it does, the clock is bad. If it does not, the touch pad is bad. Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 04, 2006 | DCS WOSD-230SS Stainless Steel Electric...
Ovens Logo
13 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
