Question about Scott LCT37SHA TV
I am trying to hook up an indoor/outdoor over-the-air antenna to the Ant 1(DTV) terminal on my Scott LCT37SHA so that I can get channels with an antenna and not using a converter box on this tv. We want to use it on another...If I hook it up through a HDTV converter box it works but I have to use the AV choice instead of DTV. I was able to get it to work a couple of times from the Ant1(DTV) terminal with an indoor amplified antenna.
  • 4,889 Answers
You just have to hook up the wire from the antenna to to the co-axial input at the back of the sett. I do not think it is a good idea though as the picture quality will be sub-standard(480i)
Posted on Jul 12, 2010
  • 484 Answers
To hook up your antenna to two televisions, you need to connect your antenna to a converter box, then you connect both television to the converter box and you will be able to operate the channels from the main television channels and not the antenna.
If you use the HDTV converter box, it will only limit you to using the AV channel to see the programs on the antenna.
You can as well get an antenna booster, that way you can connect the antenna to the booster, and connect two televisions to the booster.
Take care
  • zippywoo32 Jul 12, 2010
    Thanks for your quick response. I will use that if I have to but I was hoping to connect the antenna directly to this tv which has the NTSC & ATSC inputs.Then use the Hd converter box on the other tv which is analog.. If you need more info let me know or maybe what i am asking is impossible.
    Thanks again
  • ladipo sarumi
    ladipo sarumi Jul 12, 2010
    you actually cannot connect the antenna through the ntsc and atsc input. They serve different purpose on the television.
    It would be best connected through the booster method or the hd converter box.
    That's the best bet for you to be able to connect your antenna to both tv.
    I hope this solution is helpful to you.
    Take care
What can I hook up to this tv to get basic channels. Not cable?
Depending on your location and distance from the available broadcast outlets, you may be able to receive basic commercial broadcast channels using a simple inside or outside ad-on antenna, available from most electronic retail stores or on line vendors such as Amazon, Ebay, Best Buy, etc.
Jul 16, 2015 | Televison & Video
Cant retune through dvd player
Sounds like a few things going on here... Your indoor antenna for one is probably not making it easy for you as an outdoor antenna will work a whole lot better. This is why it open picks up half the channels and they are pixelating. Also you may have faulty rf leads. Replace these.
Feb 25, 2014 | LG Televison & Video
Antenna installation
The tuner in that unit is analog ntsc and so you need a digital converter for it.
Feb 17, 2014 | Hitachi Televison & Video
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
Nov 05, 2010 | LG 47LG70 42 in. LCD TV
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Scott LCT37SHA TV Logo
59 people viewed this question
Top Scott Televison & Video Experts
Sp Gupta
Are you a Scott Televison and Video Expert? Answer questions, earn points and help others
