Question about Toshiba Satellite A100-S8111TD Notebook
My connection from my battery to computer is failing I've had this problem fixed twice and it keeps happening. Been told nothing is wrong with battery its the connection within the computer what can I do?
  • 81 Answers
Well, if its been fixed twice already and doing it again, I would say its most likely over heating. Try using a Chill pad and on the processor clean off the old thermal compound and apply some Arctic Silver #. You can get the AS#5 at RadioShack for about $12 after tax. If your battery is getting hot enough to soften and break the solder connections i would suggest buying a new battery.
Posted on Jul 11, 2010
My car runs fine for days then i'll park somewhere and go to turn it back on and it won't start at all. It won't turn over or anything.
CHECK BATTERY CONNECTIONS, STARTER CONNECTIONS, WHAT DO YOU DO WHEN IT DOESN'T START, TO GET IT GOING AGAIN, DO YOU GET A JUMP START IF SO CHECK CONNECTIONS.
Jun 09, 2013 | Cars & Trucks
Car won't start, seems to have power, all lights working. when I turn the key nothing happens. this only happens sometimes
Could be a bad alternator.. It may not be holding charge. Or your starter could have failed.
Though I've had the same problem and it was a dead battery in my vehicle. Had enough power, but to keep the car on..
Oct 22, 2012 | 1997 Saturn SL
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
1998 Mystique wont start, ignition turns over but acts like it's not getting gas.
Does the check engine light go OUT while cranking? If not , if it stays ON, you've got a bad crankshaft position sensor. These can fail with intermittent no starts. So just when you have it towed it, it'll start working again. Check engine light is supposed to go OUT if it's getting good signal from the sensor.
Jan 01, 2018 | 1998 Mercury Mystique
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
2002 volkswagen Jetta wont start or crank, when you turn the key the cars does absolutely nothing. No lights come on or anything. Then it will start if you leave it sitting for a while sometimes, but when...
It's possible you could have an intermittent problem with ignition switch. If the battery and alternator were tested and came back fine there has to be a bad connection somewhere.
Sep 03, 2011 | Volkswagen Jetta Cars & Trucks
Help needed with starting problems. 1998 Ford Taurus SE. After driving the car for more than one hour the car will not re-start. I will turn the ignition key and nothing happen, all of the auxiliary...
Check the wire harness to the starter solenoid, the wires could have a break in it or the solenoid could also be bad. The heat of the engine could be causing the solenoid to fail till it cools down. Try that first, good luck and keep me posted, be glad to help.
Jun 15, 2009 | 2000 Ford Taurus
1990 Honda Civic dx intermittant alternator failure
along with the relay issue they some models have a very tight route for wiring from the battery to the main harness components check very carefully for any tight spots the wires may be severed also check the frame ground from the - battery terminal wire and connection itself. last suggestion do you get lights and accesories when this happens or is everything dead if you do it could be a bad connection to the starter and have nothing to do with the alternator or battery
Feb 27, 2009 | 1990 Honda Civic
Toshiba Satellite A100-S8111TD Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
