Question about Frigidaire FAP094P1Z Portable Air Conditioner
Red bucket full light stays on. - Frigidaire FAP094P1Z Portable Air Conditioner
  • 478 Answers
You need to check the float switch which sets just above,or in. the bucket, it could just be stuck or jammed it has to be able to move up and down to sense the water level.
There will be one that senses the bucket is in place that you can trick while you figure out and play with the float switch.
Posted on Jul 12, 2010
My DEHUMIDIFIER shows check-red light
well you didnt mention model but most times this occurs on dehumidifyers it means the bucket full sensor has tripped , this does not mean that bucket is full, it just means that bucket is either not seated all the way in or maybe the sensor has moved in the bucket and no longer hits the sensor as it should , try reposisioning the bucket and full sensor , ck for looseness
Nov 15, 2014 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
The "full bucket" light is blinking- and the
When the Bucket Full Light is on, none of the controls (other than the On/Off) will work. If you haven't
emptied the bucket, do so. Then make sure the bucket is reinstalled properly into the holder. Failure to do this will cause the Bucket Full Light to stay ON. While you have the bucket out, check the inside of it for a float valve. It may be stick in the UP position. If so, jiggle the handle to make it return to the DOWN position.
I hope this helped you and thanks for Choosing FixYa.
Aug 12, 2011 | Kenmore 54501 Dehumidifier
Why is the red water full light on and not worrking?
Usually, when the red water full light glows, it means that the water collection bucket is full & needs to be removed and emptied. Once that's done and the bucket is reinstalled properly, the red light will go out and the unit will turn back ON.
Jul 07, 2011 | Daewoo DHC-400 Dehumidifier
The bucket full light stays on while it is empty. the humidity control doesn't change. the unit is not going on.
There should be a switch that is activated by a float lever that if tripped will make the bucket full light stay on, and will prevent the unit from going on.
If this light is on when the bucket is empty, maybe try to jiggle the float lever, or investigate why the switch is activated when the bucket is empty.
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
If the bucket is full then the pump should be running, if the pump is not running it is a faulty pump motor, a faulty control board, a faulty level switch for the pump motor or the water level alarm float switch.
Jun 07, 2010 | Frigidaire FAP094P1Z Portable Air...
GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 19, 2008 | Dehumidifiers
Frigidaire FAP094P1Z Portable Air Conditioner Logo
213 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
