Question about Panasonic KX-TGA571S Twin Cordless Expansion Handset
Open handset for KX-TGA571A
I am attempting to open the case of the handset to reset the keys to work properly. Unfortunately, I cannot seem to open the case. I have removed to two screws in the case but I do not know how to release the upper holding mechanism. I do not want to force it and break it as a result. How do you open the case of this phone, Panasonic KX-TGA571A. Thanks.
  • Anonymous Aug 26, 2008
    OK, I solved my issue. After taking out the two screws from below the battery compartment, the case will separate slightly on the bottom. Take a screwdriver and carfully pry the case open along both sides, working from the bottom toward the top of the handset. This will free the back of the handset from the primary components. It will simply snap back together when done and then replace the two screws.
I had a similar mystery with
Posted on Aug 12, 2008
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
Oct 04, 2013 | Uniden Lands Phones
Keypad not working 1208
This is issue is quite common on most handsets, regardless of the manufacturer. What happens is that the handset will freeze up, and simply resetting the device will rectify the issue. The first thing that you will want to do is to make sure that the handset is on, and then remove the battery. This is called a hard shock and will reset the handset. Once you have removed the battery you will wait approximately 1-2 minutes and then reinstall the battery, then the cover and then you will power the handset on. Your keys should then be working, and if they are not, then you have something that is going on with the computer board in the device and it may be covered under warranty by the manufacturer if the device is under a year old. If this is the case, then you will want to call your cellular provider to file an insurance claim.
Feb 21, 2011 | Nokia 1208 Cellular Phone
I have a nokia 5800 n in it wave secure is bering installed i want to delete taht but i dont know the password
you must remember your e-mail id that u used while regestering wavesecure.
proceed as directed,
goto this link and enter the name that flashes when you open wavesecure.
enter image text and click below.
NOTE
Before you do this i repeat the very important point.
do this only when you are 100% sure that your recovery e-mail id is correct and working.
if this is not the case then there is only one way left.
backup all the data and hare reset your phone.
In order to perform a hard reset on your Nokia 5800XM, enter the following key combination Ensure your handset is turned off then,
Press and hold the, Green key, Red key + Camera Key and press the On button.
The device will then resert in it’s default factory settings with all handset data removed
Apr 04, 2010 | Nokia 5800 XpressMusic Smartphone
Panasonic KX-TG2356 Cordless Phone key pad
Open the hand set by Removing battery, remove 2 screws under battery, carefully open handset casing by prying open with thin bladed screwdriver, remove pc board by removing 3 retaining screws, on opposite side of pc you will see contacts for handset buttons clean with eraser and reassemble handset.
Jan 24, 2010 | Panasonic KX-TG2356 Cordless Phone
My Toshiba Satellite P105 touchpad and keyboard are not functioning. It almost seems that I have somehow locked or disabled it. I can plug in a USB mouse and get to my desktop to open progams and such but...
If only some aren;t working, attempt to clean it with compressed air (fter verifying that this is safe for your computer).
If all of the keys aren't working then most likely this is hardware related. Faulty wiring replacement should only be attempted by a professional (unfortunately).
The last thing that comes to mind is that someone spilled a liquid within your keys =P
Sep 28, 2009 | Toshiba Satellite P105-S6104 Notebook
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Bt graphite handset states out of range but is on base
the manaul states that by resetting the phone should solve this. In my case removing the batteries from the handset for a couple of seconds seemed to work just fine.
Regards
Mar 26, 2009 | Lands Phones
HELP!!!
i think the keypad sensor is the problem ...
if your good at opening then just remove the handset take off the keypad check the keypad is it in good condition or not ..
if not you replace with the new one ...
& also clear if there is any obstacles in the keypad sensor ...
this will solve your problem .
it cant be the firmware problem so just do this it will be fixed ..
if you are not good at opening then just tap the phone lightly so that if there is any loose contact in the keypad with sensor it may get fixed .... otherwise you must & should open the handset & do it ...
if you are afraid then just visit the technician ...
it is just a matter of some bucks ... i think you can only do this simple thing by opening...
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Jul 02, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Panasonic KX-TGA571S Twin Cordless Expansion Handset Logo
213 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
