Question about Grilling
Can't light Lodge Outfitters turkey fryer
I have a 30 qt stainless steel turkey fryer made by Lodge Outfitters. I lost the instructions and do not how to light it. It is not as simple as turning on the gas and pressing the starter.
Turn the timer knob to on. there should be a plunger type button on the botom of the timer. H old this in while pressing the igniter.Continue to hold plunger in for about 10 seconds after the burner lites. If you hear the flame go out , relight and hold a little longer. The timer knob will shut off after about 20 minuites
Posted on Nov 22, 2010
I have lost the instruction booklet for Cooks Essential 12 qt. air fryer. Do you have it available online?
QVC lists the K43782 Cook's Essentials 12 qt air fryer here: http://www.qvc.com/CooksEssentials-12-qt-Air-Fryer-w-Rotisserie-%26-Accessories.product.K43782.html . There is a link to the User's Manual below the Description header. The direct link to the manual is http://www.qvc.com/footers/cd/pdf/K43782-OwnerManual.pdf .
I hope this helps.
Aug 08, 2016 | Nesco 12-quart Professional Stainless...
Tip
Bypass Brinkmann Turkey Fryer Thermocouple
I bought my fryer in November 2010 and it worked good for that Thanksgiving. Went to use it this year and thermocuople kept shutting off. So I used a brick to kep red button pressed in. What a pain.
After turkey day I removed my thermocouple and installed a direct conection.
I'm not sure about the exact thread size the Brinkman hose end and brass fitting on burner uses. I tried using a 1/16" NPT fitting but it is incorrect. However, I found 8mm threads to be the closet. Use thread sealant and it works great!
I bought a McMaster-Carr p/n 93590A220; Metric 18-8 Stainless Steel Coupling Nut M8 Screw Sz, 1.25mm Pitch, 38mm Length, 16mm Width, $7.95. and used it to connect the hose end to brass fitting on burner.
Yes this is considered a safety risk so modify at your own risk. No one I know of ever walks away druing use.
hth
Kenneth
on Dec 05, 2011 | Brinkmann 815-3786-0 Turkey Fryer
How to assemble
Show me how to assemble a kamp turkey fryer
Nov 23, 2015 | Kamp Kitchen 30 QT. Stainless Steel Turkey...
How big of turkey will a Morrone TKF 300 A turkey fryer cook.
Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
Oct 21, 2014 | Grilling
How to do cheat
Not sure exactly what you're asking due to a type-O. But, I going to assume your meant "How to do heat".
Admittedly, this is not the easiest electric turkey fryer to start out with, but it does do the job pretty well.
To start heating the oil and setting the cooking temperature, you must do the following.
Press "ON"; then "Temp Heat"; then press the up arrow until it reaches 400 degrees (for frying a turkey). You may have to push a button more than once, because I think the first push is to light up the screen.
Hope this helps you solve your problem and gets you going.
Feb 18, 2011 | Cajun Injector Deluxe (30 Qt) Turkey Fryer
LOST INSTRUCTIONS ON SETTING IT UP
Get the manual for the Turkey fryer.You will get the instruction from there.
Nov 25, 2010 | Char-Broil Big Easy OilLess Infared Turkey...
Grilling Logo
272 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
