Question about Sharp R-1500 Microwave Oven
Start button fell inside the panel
The Start button on my microwave just fell right into the side panel of my microwave when I pushed it "on" and now, of course, nothing works. This thing has been a problem since the day I bought it and I wish I had never been captivated the the "works inside the door" feature, which I thought was pretty cool. Help!
  • Sharp Master
  • 9,086 Answers
You can get new & improved buttons here: http://microwavedisplay.com/btn_form.htm
We also have the full service manual on our site:
http://microwavedisplay.com/r1500_r1501_r1505_r1506_sm.pdf
Pages 29 & 30 cover removal of the control panel assembly or see the video at our site for a quick head start.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Jun 25, 2012 | GE SpaceMaker Microwave Ovens
Paint coming off inside microwave and buttons at control panel pushed inside of panel so unable to use
The keypad control board may have to be changed, also the cavity paint must be replaced with the right type of compound for microwave ovens.
May 18, 2012 | GE JVM2070 Microwave Oven
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
The oven control panel won't let me push light and work. Even when putting in the times for microwaving, the start button won't work. The panel seems to not be working. Do I need to replace the panel?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it is just failing to start when you press "Start", it may just be a door switch or mount. See this file.
If several keys are not working, it is almost certainly a bad keypad.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me directly (and mention your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 14, 2010 | Amana ACO1840A Microwave Oven
Problem with light,vent, and the boost
Depends on the model #. I dont see it on here. This unit may have some kind of button assy that has broken and fell back into control panel.
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
Outside glass dooor on Whirlpool oven fell off, what do i do?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 15, 2009 | Whirlpool MH1150XM Convection/Microwave...
Our MH7130eq microwave will not start after pushing the start button on The clock, timer, hood fan works, however the micro will not start
Check the door safety switches . remove the cover ... look on the right side near the top. Just because they sound like they are working doesnt mean they are working. Sheck them with an ohm meter or other contunity tester.
Door switches are the most common reason for microwave failure.
Sep 07, 2009 | Whirlpool Microwave Ovens
The button to push that turns the microwave on won't stay pushed
When you hold a button in you are bypassing the safety controls Marian. Microwave energy can be deadly so you are taking a chance here. I recommend you consider replacing the oven as the new ovens are cheap and have great features. Service on these units cost more than a new unit.
Ray
Nov 28, 2008 | Magic Chef Microwave Ovens
Start button problem
You will need the new & improved select button assembly and you can order them through us if you like.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
The order form is at http://207.234.249.73/mwd/btn_form.htm
Nov 25, 2007 | Sharp R-1501 Microwave Oven
Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
Jun 04, 2007 | Sharp R-202EW Microwave Oven
Sharp R-1500 Microwave Oven Logo
114 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
