Question about Kenmore Ovens
The led display lights have dimmed so much I can't read the. THis is a built in double oven - Kenmore. not sure of the model #
    President:
  • 1,891 Answers
You will need the model # to get the correct control panel for this range . the display has failed and ony repair is to replace it . part # may be on control . and inside the control area there should be a tec sheet with this info .. mm hope this helped ..
Posted on Jul 16, 2010
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Jen Air double oven only beeps when you make any selection.
can you look real close at the display, its possibel that the display has "dimmed" and unit is actually working, but just cannot read the display as to what its actually doing, in this case replaccingthe display board will correct your problem
Mar 08, 2009 | Jenn-Air JJW8230D Electric Double Oven
Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
177 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
