Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Briggs 21 hp OHV motor will not start after internal work.
I had to replace the piston connector arm on my Briggs 21 hp OHV motor. It was quite a job. Luckily there was no damage to the cylinder or crankshaft. The battery was dead so I jumped it from the car (it appears to be holding a charge). The starter does works, and the mortor turns with ease. The spark plug is working (sparks against case) and it looks wet after cranking so I think there is fuel getting to the motor. Yet, the engine will not start. I'm at a loss at what to try next. Could I have messed up the timing? I lined up the timing marks on the fly wheel and crankshaft gear. Or maybe something on the carburetor. Thoughts.
    Top Expert:
  • Briggs & Str... Master
  • 50,583 Answers
Most likely that the timing is not correct
you line up the dots on the crank gear and the cam gear not the flywheel and the the crank shaft dot
the plug will spark every time the flywheel magnet passed the coil
Posted on Apr 05, 2017
SOURCE: 24 hp briggs intek vtwin won't start
This same thing happens to me and I resolve it by taking the gas line off in front of the carb and blowing air through it.....then it will run fine. I realized I could do this when I took the air cleaner off and fed it gas manually and it ran fine....and I also had gas pumping through the fuel pump. I'm not sure of the problem....either the fuel pump is losing power or their is something blocking the carburator intermitantly
Posted on Jul 14, 2009
davesoucy
  • 148 Answers
SOURCE: 14hp ohv engine getting very hot,briggs
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Posted on Aug 05, 2009
  • 3 Answers
SOURCE: 2.5 year old, 15.5 hp Briggs cranks but wont fire
make shore that the valves are not rideing no tappet clearance back both roccers of and try for comp there has to be a tappet clearance for there to be comp or set the inlet at 5 thou and the exhaust at 10 thou on the comp stroke .horizontal b/s have a very good past very good engine in the past
Posted on Sep 02, 2009
peterrance19
  • 399 Answers
SOURCE: I get one spark on plug, then nothing. It is a
hi y could have a sticking float in your carb causing it to flood
Posted on Nov 15, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a briggs -stratton 12 h.p. engine on my
Hi and welcome to FixYa I am Kelly.
This post is listed under the Intek V-Twin engine that would be engine model number 281707-0148-01 so I am making my recommendations based on that model number. If your ENGINE model number is different from the one above please respond with the number.
It sure sounds like there may be a compression problem. All other elements
Fuel, Air and spark are in place. If you can not get even a backfire it sounds like there may be a valve sticking open. Probably more than one if not even one cylinder is firing.
I have one question..... Has this engine been sitting unused for a while?
Lets start with something simple. (again based on 2 cyl engine but procedure would be the same for a single cylinder)
1. Remove both spark plugs
2. Spray a very generous amount of WD 40 in BOTH spark plug holes.
3. Use the starter and turn the engine through for about 5 seconds
4. Again spray WD 40 into the cylinder head via the spark plug holes and let it soak for about 15 minutes.
5. Turn the engine through again with the starter for at least 15 seconds. Pause 1 min and then another 15 seconds.
6. With assistance Use your thumb to cover the spark plug hole opening and check each cylinder for compression
Compression = Yes / Install spark plugs and try starting.
Compression NO ... If engine is OHV remove valve cover cap(s) and spray WD 40 through the valve springs onto the valve stems then let them soak for about 15 minutes.
Flat head engine
Remove cylinder head only and check the valve seats for coking in the seats. ESPECIALLY the exhaust valve. There should be a visual ring where the valve mates to the valve seat. If you can not see a visual ring then the valve seats should be hand lapped with valve grinding compound. (Valve Spring will have to be disconnected but NOT removed to hand lap with valves grinding compound)
Once you get a ring that you notice on the valves then reconnect the springs and install the head.
Check for compression with your thumb by having the engine turned through.
You really should have compression at this point.
Install spark plug and start the engine.
If you need more assistance or.. have a different model number other than the one above... then just respond here and some one will help you.
Thanks for using FixYa.
Kelly
Posted on Apr 14, 2010
I have a 21 hp Briggs and Stratton model #331877, what are the valve settings?
Intake 003 - .005
Exhaust .005 - .007
Adjusted with the piston 1/4" past TDC of compression stroke for each cylinder.
Apr 10, 2015 | Craftsman Garden
How to fix seized briggs v twin
may be excessive carbon buildup from using oil on one cylinder. remove head and decarbon with a wooden instrument.
Apr 18, 2013 | Briggs & Stratton Briggs Stratton Intek V...
18 hp Briggs blowing oil into the air filter
Sounds like your valves are sticking, possibly bent w/piston damage.
Dec 14, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Replacing ohv cam on 17.5 briggs model 31c707-1346-b2
if you dont know take it to a proffessional if you make the slightest mistake you can bend valves or even worse break a piston
Oct 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
No compression when the rocker arms are on
Work through it step by step
options are
valves not seating
valve guide dropped and holding the valve open
broken or weak valve spring
piston holed
rings completely shot
hole in cylinder wall
all involve a top end stripdown a the least
have fun and it should be obvious when stripping. the valve guide may not be so easy to spot they should be equal heights frm the head
Oct 19, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a briggs 22 hp vertical ohv that is about 6 years old. It is burning oil badly but still runs the mower. I worried that it was undersized for a 48 inch deck with a hydrostatic transmission. Is it...
It will give you a bit more service. However one should also replace bearings in crank and rod. I would purchase a new 6 hp from harbor freight for $100 BUCKS.
Nov 09, 2017 | Briggs & Stratton Briggs Stratton Vanguard...
My 24hp Briggs and Stratton ohv engine has bent push rods on one side. The top valve can be pushed in but the bottom one will not push in. Is the valve stuck in the open position? If so how can it be...
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Apr 12, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Engine turns over but cylinders do not move up or down.
If by what you are saying cylinders don't move up and down this would be the pistons. Most likely you have a broken crankshaft or connection rods.
Dec 23, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
561 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
