Question about Toshiba Satellite M45-S2692 Notebook
System does not boot Possible Hard drive issue
Yesterday I went to power up the computer and the sytem failed to boot. I tried to reboot several times, before I decided to tilt the laptop back while booting. Amazingly the system booted like normal. This morning ran into the same problem, so I plan on replacing the hard drive. How does one access the hard drive on this model for replacement?
  • dchearis May 06, 2008
    WILL NOT BOOT TO WINDOW
    Scholar:
  • 87 Answers
Hiya. Why replace the hard drive? When you say your computer failed to boot - are you sure it wasn't booting? Maybe it did boot but your screen remained blank. It sounds more like a screen problem, quite likely the ribbon connection is loose or it could be damaged. Its a very common problem and tilting the screen moves the ribbon a fraction and it then makes the connection. Try switching on and if the screen is totally blank, no message at all, no flashing cursor then its the screen. If you wanted to be 110% sure, easiest way is to connect laptop to an external screen and test it that way. Hope this is helpful.
Posted on Apr 23, 2008
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Can not boot up computer
possible your hard drive
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Media test failure message. Reboot and Select proper boot device
hope this helps
My tosshiba satellite A665-55186 wont go in to windows boot, what can i do??
Just like other computers, your Toshiba laptop may start failing to boot the operating system completely, or may fail to boot up at all. Boot problems are caused by virus infections and issues related to hardware and software. With the proper troubleshooting techniques, boot problems can be remedied to get the laptop into good working condition.
1. Perform initial hardware checks. Ensure that the laptop has enough battery life to boot up. Charge the laptop using its AC adapter and then try to boot the laptop again. If nothing happens, plug the AC adapter into another power outlet. If this does not help, check to see if external drives (flash drive, external hard drive, etc.) are connected into one of your USB ports. Unplug it from the laptop and press the laptop's power button. If the laptop powers on but fails to load the operating system, proceed to the next step.
2. Ensure that the hard disk is not disabled in the boot sequence in your BIOS. Otherwise, the laptop will fail to fully boot the operating system. Reboot the computer and press a key that will lead you to the BIOS page. Set your hard disk as your "first boot priority," or first in the "boot sequence." Note that the steps on loading the BIOS as well as navigating throughout the BIOS pages will depend on what brand of BIOS is installed in your laptop.
3. Choose boot to the "Last known good configuration" if you get an error page before the operating system boots up. If after choosing this option the computer reboots again, choose "Start Windows Normally," if this is in the list of options.
4. Consider repairing or reinstalling the operating system if the computer still fails to boot after the steps above. Repairing the operating system will retain your current data and settings. Reinstalling the operating system means reformatting or deleting all data in your computer and installing a fresh copy of the operating system.
I hope you find it very helpful. Best regards from fixya
Aug 15, 2011 | Toshiba Satellite A660 Series Notebook
I have installed a brand new 10.5.6 on my G5 2x2 dual. After i had installed the system i configured the safety so that it would not even be possible to reboot without password from another disk or drive....
Trying booting from the Mac OS X install disc. insert the disc while holding the "option" key on the keybaord select the Mac OS X disc. once it has started select the Utilites from the menu bar from there you will see a "Reset Password.." select the hard drive select the user account enter password reenter the same password give yourself a hint to the password
at the bottom reset the "Home Folder Permissions and ACLs"
click save
reboot the same way, holding the "Option" key select the hard drive enter the password for the account you just made
once you have booted into the system go to: Apple menu (top left) > System Preferences > Startup Disk
make sure that you have your hard drive selected this makes it so after a reboot it will boot from the hard drive and not a disc.
Nov 20, 2010 | Apple Power Mac G5 Desktop
Need to find the NTLDR on my emachine I tried the recovery disk option to reset the reboot option - and was still unable to correct the problem. Are you aware of another solution? Thank You
A couple of things.
If the system has a floppy diskette drive, ensure that no diskette is in the drive. (I know it sounds simple but ...)
If no floppy drive issue, then run diagnostics on the hard drive. The drive may be failing.
Last you can try booting to the XP CD enter recovery console, and run the command: CHKDSK /R, then reboot.
My impression, if no floppy drive issue, then failing hdd
Jul 02, 2009 | E-Machines eMachines Desktop PC
Hard drive not installed
Try booting from the Operating system disc, into the recovery console.
check when booted, where your hard drive is.
if not try safe mode, reboot tapping F8 while booting,
choose safe mode from list, check for hard drive when booted in places like,
My computer, device manager, anywhere on the desktop if you get there,
If your savvy, ESD kit, check connections to hard drive, swap out cables if poss.
it's on IDE so no SCSI driver issues..
But if powered up, and cannot be located on desktop after multiple checks,
That's a possible hard drive failure.
Regards.
Apr 11, 2009 | IBM ThinkPad T20 Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
279 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
