Question about HP Photosmart 2410 All-In-One InkJet Printer
Using a calling card for a long distance fax
I want to know how I can send a fax long distance using a calling card.
    Problem Solver:
  • 12 Answers
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Posted on Jan 20, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Calling cards are not meant for just calling they can also be used to send faxes. It is beneficial to use calling cards because somewhere it helps you to save a little money while faxing long distance. For faxing you just need a calling card, a fax machine and set it up as a normal fax machine. But while using calling card you need to dial your calling card number instead of receiver's number on fax machine. Next the fax machine will ask to enter the calling card PIN. After entering your PIN number your fax machine will allow you to enter your destination number with country code. Once you hear the fax tone then you just need to press "SEND" button. This is very simple process to do fax by calling cards. I also use my Reliance Global Call Enterprise Calling Cards for long distance fax. It is quite simple, cost effective and easy to use. Get more info about Corporate Calling Cards
using a calling card for a long distance fax - using-calling-card-long-distance-fax-vge3qktokg1smsf4c3ydt4xa-4-0.png
Posted on Jul 27, 2016
HP PSC 2410/2510 Photosmart All-in-One - Using a Calling Card for Faxing (Stand Alone) using a calling card for a long distance fax - s.gif s.gifusing a calling card for a long distance fax - s.gifss= s.gif
ISSUE: How to use a calling card to fax (stand alone) with an HP PSC 2410/2510. SOLUTION:
  1. Press the Setup button.
  2. Scroll down to Speed Dial Setup and press OK .
  3. Press OK on Individual Speed Dial .
  4. Scroll to an unassigned speed dial or select and existing speed dial to edit and press Enter .
  5. Enter the number for the calling card including any responses to the IVR prompts such as Press for 1 for English , Press 1 for long distance , Please enter the PIN number , etc. Any of these responses would have to be separated by pauses to line up appropriately with the IVR prompts.
  6. The pause is done by pressing # twice on the printer until you see a minus sign (-). NOTE: All calling cards are different, you will have to know what prompts there are in regards to Language, Pin number, Long Distance, etc.
  7. Press OK on the printer after completing the speed dial.
  8. Enter the name for the speed dial and press OK .
  9. To use the speed dial, press Fax button on the printer and you will be prompted to enter a number.
  10. Press Down Arrow to select speed dials, select the appropriate speed dial and press OK .
  11. With the speed dial selected, press BLACK or COLOR start button to send the fax either in black or color.
Posted on Jun 04, 2008
Can receive faxes but can't send
It almost seems your HP machine is arbitrarily denying you access to long distance numbers. Try referring this issue directly to HP for an explanation.
Dec 20, 2013 | HP Officejet Pro L7590 All-in-One InkJet...
I would like to send a fax long distance using a calling card. I tried but it won't go through. Can it be done? I could do it on my other HP.
would like to send a fax long distance using a calling card. I tried but it won't go through. Can it be done? I could do it on my hp 6500 printer
Dec 29, 2009 | HP Officejet 6500 Wireless All-in-One...
I don't have long distance service on my land line. I need a code to send long distance faxes
You might try purchasing a calling card for long distance. That would provide a code.
Aug 29, 2009 | HP Office Equipment & Supplies
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Fax using a calling card
I use a calling card for long distance faxes. You don't have to "set" anything. They just mean listen to the printer. I am not at home right now to get the specific steps, but I believe all you do is put your fax stuff in the document feeder (I don't know if you can do this directly from the computer) and enter the 1-800 number from your calling card. Then the calling card will ask for your options and you will hear it from printer. That's what they mean by monitor. Then just follow the prompts.
Jan 30, 2009 | HP OfficeJet 7310 All-In-One InkJet...
When I try to fax there is a beeping sound. the report says the line is busy/noresponse
i would first reset up the machine in send and receive mode, is there dial tone. let me know what happens
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Faxing
Normal 0 Sending Fax Using Calling Card:
Load document in the ADF
Press [FAX]
Adjust settings for your documents as necessary
Press [Hook] Alternatively, you can lift the handset if one is connected to the machine.
Dial your calling card information responding to all calling card prompts on the fax key pad. After dialing the recipient’s number using the numeric keys or speed dialing, wait for the high-pitched fax signal.
When you hear a highpitched signal, press [Black} for black & white sending.. Hang up the handset if you used it.
Oct 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Hp L7580 fax machine
set up the fax driver in windows printers and faxes menu with the calling card prompts. you can use commas between sets of numbers for 2 second pauses. such as (example) 9,,1800callmci,,,2,,3,,cardnumber,,,4digitpin,,3685551212, - in this fashion, you can edit the fax number here before sending the fax.
Sep 24, 2008 | HP Pavilion dv6000z Notebook
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
HP Photosmart 2410 All-In-One InkJet Printer Logo
659 people viewed this question
Seeker5211
Seeker5211
