Question about Fein 9-55-13 Turbo II Bagged Canister Vacuum
Fein 9.55.13 is very loud
Is there a way to suppress the very loud buzzsaw noise in my fein 9.55.13 PE vacuum?
My vac is so loud I can't talk above the nois
Bearings and or a van/disbalans broken paddle or a defect commutator ( a collector is broken out from the armature)
May 27, 2014 | Fein Vacuums
Where could i buy a new switch and capacitor for my multimaster Msxe 636 - 2thanks
A capacitor is in in practice not nessecary but sometimes its only inside for radio interference suppression. remove it the switch is if you not know it also made to disassemble because of all its a realy dirt sensitive, but rarely defect i have never replace this part in all the time this year 20 years switches of this model al very little screwdriver is neccesary open it a little not neccesary to dismount it completely and spray wd40 inside wait a moment and blow the dirt carefully out remount and control always the AC cable for shure after.
Jan 28, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Replace the oscillating fork in a fein msxe 636
beware of the materials that are used are usually very soft witch used by Fein in his budget machine class.
puler
Only a dutch version but the same parts positions.
MSxe 636 II 50Hz 230V
Jan 05, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Where does the long lead go on my multimaster capacitor go
Close to the bottom in the corner near the motor stator (= electric field) between the machine housing and the stator there is a narrow metal strip connection point visible which makes contact with the metal outer surface of the stator, the strip sits against the corner on the underside between the motor stator and the machine housing from the front so pushed to the back comes out so at the contact side of all sliding contacts you will see are that part, I myself always recommend letting eight jure the capacitor because it only makes sense for radio interference suppression only at work places.
Aug 22, 2012 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Need switch for Fein mdl 9355.13 vac. Where to purchase?
Type www.fein.com in the address line in browser. It should take you to Fein in your country. On the left hand side of screen you will see a list of links click on service then Authorized workshops that will give you a list of places to fine spare parts and repairers.
Mar 26, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
FEIN 9.55.13 WILL NOT TURN ON. SWITCH? BRUSHES?
replacement parts for that model can be found at amazon, click here and take a look: Amazon com fein vacuum parts . Have a nice day
Sep 12, 2011 | Fein 9-55-13 Turbo II Bagged Canister...
A friend who bought a multimaster less than a year ago has had his start a loud 'clattering', dry, noise, and the gearbox started to get hot. The output shaft now has about the same amount of slop as the...
Fein is an excellent tool and has an excellent warranty that will be void the moment you open the gearbox. I do not recommend this action. Fein is quick and responsive, especially for a less than one year issue. Farmerbear at FixYa.com
Sep 30, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Motor is getting louder and louder, too loud to use
Bearings of the motor REPLACE always the complete motor if its worth to do . if it comes in line with the general state of the remaining whole
Sep 22, 2010 | Fein 9-11-55 Canister Wet/Dry Vacuum
Where can I purchase a switch for the MSxe 636 II Fein Multimaster?
http://www.ereplacementparts.com is one of the online shops in you Country or a dealer for FEIN in your immediate environment.
Jul 29, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Are fein vacumes anti static?
all vacuums create static from friction even plastic cased ones
May 18, 2010 | Fein 9-55-13 Turbo II Bagged Canister...
Fein 9-55-13 Turbo II Bagged Canister Vacuum Logo
424 people viewed this question
Top Fein Vacuums Experts
Marvin
Marvin
Bill Boyd
Dan Apthorp
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
