Question about AT&T Samsung A127 Pay-As-You-Go Cell Phone - Red
No Signal/wrong setting?
The phone is not getting a signal and I do not have the owners manual any longer, looking for the settings to make sure it is set to automatic and not analog?
  • 1 more comment
  • Anonymous Jan 20, 2009
    Signal is gone system completely reseted to october 1st and i need help whats should i do?
  • Anonymous Jan 28, 2009
    mine suddenly lost signal too.
  • Anonymous May 12, 2009
    mine recently just lost signal too and wont let me send messages or anything
Nokia 7260 no signal
Posted on Aug 16, 2008
My wall clock no longer accepts the correct time signal.
then you have the wrong time zone set in . with no MAKE we can not assist you
May 13, 2016 | Home
Emerson model LC391EMI, How do you turn on the 1080 feature.
If its 1080 it must be connected with signal to a 1080 input---be sure to check owner manual as some sets are only 720 etc and will not support 1080.
If in doubt try to Google the model number for 'specs" or "manual".
Set if 1080 and getting 1080 signal via correct connections will automatically show it.
May 21, 2012 | Emerson Televison & Video
My magnavox LCD 32
Look in set up menu and owner manual---something is set wrong--also if using box for signal check to see if the menu you are seeing is the box's or the sets menu.
Apr 01, 2012 | Televison & Video
Not available is all I get from the cordless phone which used to work with this phone. I have tried everything and can't get the cordless extension phone to work with this base.
It sounds like the extension phone needs to be keyed-in to the signal frequency of the base unit. It could have lost the frequency key for several reasons. 1st, make sure the battery signal is not showing a low battery. Next, depending on the model, you may have to sit the extension phone in the cradle on the base unit in order for the signals to coincide, or you may have to remove the battery from the remote phone for one minute to allow it to reset itself, or there may be a set (combination) of key buttons that need to be pressed to make the signal transfer between the remote and base, then it will lock-in and work normal from then on. You need to consult your owners manual for this set(combination) of buttons to depress if this is the case. If you do not have the manual, you can go to (that's owner iQ) I'm reasonbly sure it is .net and not .com; good luck, Macgivor.
Oct 04, 2009 | General Electric 25983EE2 Corded Phone
We cannot receive faxes in
First thing to look at, that is if you can send. Look and verify that the phone line is in the "line" jack and not the extension or phone jack.
Then be sure the fax settings are these. ECM is ON, Secure fax is OFF, Delay fax is OFF, and Junk Fax is OFF. Those 3 being set wrong will also cause that problem.
Another cause is a noisy phone line, or if the machine is on a digital phone line. Ex, DSL line.
Unlike sending, where you make an actual physical connestion, when you receive the line voltage and current have to be correct. So a phone line issue is possible. I relate it to haveing a tv remote with weak batteries. If they are low, there is not enough signal to chnage stations , volume etc. If the line signal to the fax machine ie weak, there is not enough signal to turn the fax receive on.
Start with the location of the cord, then the settings, the suspect the phone line. It is almost NEVER the machine, unless you experience a lightning strike.
Jul 10, 2009 | Xerox Phaser 6110 All-In-One Laser...
Gps wont pick up satilites
Make sure all the connections at the back of the unit are tight. If it still doesn't respond try a new puck.
Apr 15, 2009 | Lowrance Globalmap 5300c Igps 5" Screen...
Ive connected the vga cable and still get "NO SIGNAL" msg.
If the resolution of the source of the RGB signal is outside of the range of the set, you will get this mesage. The supported resolutions are listed in the owner's manual. Verify that you have a signal within that range. If you do, please post your source of the video here and we'll look further.
Mar 19, 2009 | Vizio VOJ320F1A 32 in. LCD TV
My nokia n70 phone weak of signal
hi im josh in cebu phils.friend may i help you? your problem is weak signal. friend when the phone is weak signal there maybe a problem in hardware of the phone. the frequency reciever is weak im sure.but you can boost its functions throught entering the setting and go to network settings and select manual search.your phone frequency will search the network connections around so the hardware will be force to boost.once it will show the network providers around you select the network you are using and it will be setted to the network in more/ higher frquencyh signal. thats all friend hope i helped you.good luck/
Feb 28, 2009 | Nokia N70 Cellular Phone
my father gift c168i phone to me but when i use my SIM there a message..." NETWORK PIN" can i know the process to know the network pin of Smart SIM..pls help me..
thank you...
Oct 05, 2008 | Motorola Mobility C168 Cellular Phone
Signal tone for SMS messages
Try same code to reset *2767*3855#
Oct 19, 2007 | Samsung SGH-D500 Cellular Phone
AT&T Samsung A127 Pay-As-You-Go Cell Phone - Red Logo
170 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
