Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
So i went and got oil and they gave me non detergent sae 30. should i use that.
  • 10,865 Answers
Hello. Yes. This is the recommended oil. Here is the owner manual and you can check on page 6 to verify. http://www.managemylife.com/mmh/owner_manuals/8213/CRAFTSMAN-Air-compressor-L0409630?brand_name_search=craftsman+1.5+hp+compressor
J.
Posted on Jul 19, 2010
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What oil to use?
what is recommended in the owners manual if not sure try Google Make model and manual
May 18, 2015 | Garden
What is an alternative to sae-30 non-detergent oil.
A two stoke oil is a non detergent oil and is mixed with the gas for two stroke engines. If you are looking for an oil to add to the crankcase of a four stroke engine, you are better off with a detergent oil, the detergent and additives are make to keep your engine clean by attracting the particles in the engine crankcase.
Jan 26, 2015 | Garden
I need a manual for the Craftsman Walk behind mower #917.388930. The main thing I need to know is when changing oil what is the capacity? SAE 30 non detergent I assume. Thank you.
No, you do not use non detergent oil. You must use only SAE high quality detergent oil with API service classification SG-SL . Use SAE 30 weight or 5W30 if you use the mower during cool conditions below freezing. I highly recommend you use Synthetic oil in this air cooled engine and change your oil once each year. The oil capacity is 20 ounces. You can see the owner's manual at this link. Just click Manual Location and put in the captcha and click submit. No need to sign in or register. http://www.hammerwall.com/Manuals/Craftsman/Description/917.388930/Craftsman%20Walk%20Behind%20Lawn%20Mower%206%20HP%2021%20Inch%20Rear%20Discharge/L0605486/
Jun 27, 2011 | Craftsman Garden
What oil goes in this unit?
Hi and welcome to FixYa, I am Kelly.
This response applies only to the engine:
Use 30 WT SAE engine oil.
You can use either detergent or non-detergent oil. I recommned 3 oil changes normal oil change intervals using 30 WT SAE non-detergent oil and on the 4th oil change use a detergent 30 WT Oil.
Thanks for choosing FixYa,
Kelly
Apr 17, 2011 | Honda 2500 PSI Gas Pressure Washer
What type of oil is needed for a Honda GC160 Power Washer? Honda 2500 PSI x 2.3 GPM.
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
May 27, 2010 | Honda Pressure Washer PSI 3000
What type of oil does remington 3.5 electric saw uses?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 (30 weight non-detergent oil) with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Remington 16" Electric Chain Saw
What kind of oil should i use for a 2004 Chrysler town and country?
Driving conditions / oil
(Note all oils are NON-DETERGENT)
City hot / SAE 20W - 50
City warm / SAE 10W - 40
City cold / SAE 5 -30 or 5W-40
Rural hot / SAE 20W - 50
Rural warm / SAE 10W - 40
Rural cold / SAE 5W - 30
Brand does not really matter as the SAE designation makes them all the same other than a few manufacturer specific additives i.e Techron ect.
Feb 14, 2010 | 2004 Chrysler Town & Country
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Oil type
ENGINE OIL
Caution
Never use non-detergent or straight mineral oil.
Oil Identification Symbol
Use only engine oils displaying the EOLCS certification mark on the container.9a2551f.jpg
If these oils are not available, an API classification SH ECII or SH/CD EC11 can be used.
Oil Viscosity
SAE 10W-30
NOTE
l SAE 5W-30 may be used for operation in very cold weather
areas where the lowest ambient temperature is below
- 10°F (- 23°C).
Oct 29, 2008 | 1999 Dodge Avenger
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
100 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
